[postgis-users] execute 'alter table' won't work
Peter Bange
bange at argoss.nl
Wed Apr 18 04:35:20 PDT 2007
Anybody an idea why this won't work, I am checking if a table has all
the columns I need:
for rec in select shortname from atb_pollutants loop
-- loop over pollutants
BEGIN
strSQL = 'alter table atb_compositions add column ' ||
rec.shortname || ' real';
execute strSQL;
raise notice '... added';
EXCEPTION
when duplicate_column then
-- take next
raise notice '... already existing';
END;
end loop;
I get the notice ' ... added' for all non-existing columns in the
table (so I assume no error has occured) but when I look in the table
not a single field is added. And indeed, when I run the same code
again I get exactly the same ' ...added' messages. (The notice
'...already existing works fine for all the columns already in the
table.)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070418/0dab59e5/attachment.html>
