[postgis-users] Shp2pgsql problem 2
Frank Koormann frank.koormann at intevation.de
Wed Apr 18 05:47:57 PDT 2007
* Stefan Hahmann <s.hahmann at mapchart.com> [070418 14:08]:
> Oops,
> Sorry actually i did
> shp2pgsql -s 4326 -a -I -D -k myshapefile2.shp public._g24 | psql -d mapdata
> And then i got the error.  (ERROR:  syntax error at or near "2760003221743" at character 1 LINE 1: 2760003221743 4110 0 100000000005583 0 522760200562014 0 0 1...)
> I have copied the lines to http://paste.lisp.org/display/39917
I successfully ran a completed version of your excerpt without errors.
I noticed, that the data row you uploaded is
522760003221743        4110        0        100000000005583  .........
but your error message states
--> Where is the leading 52?
Have you tried to save to sql commands into a file instead of using a
pipe and then loading via "psql -f" ?
Regards,
        Frank
Frank Koormann    |   ++49-541-335 08 35    |   http://www.intevation.net/
Intevation GmbH, Osnabrück, DE | Commercial Register Osnabrück, HR B 18998
Managing Directors: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
PostGIS Support (http://www.intevation.net/geospatial/postgis-support.en.html)
