AW: [postgis-users] Shp2pgsql problem 2
Stefan Hahmann
s.hahmann at mapchart.com
Wed Apr 18 05:06:35 PDT 2007
Oops,
Sorry actually i did
shp2pgsql -s 4326 -a -I -D -k myshapefile2.shp public._g24 | psql -d mapdata
And then i got the error. (ERROR: syntax error at or near "2760003221743" at character 1 LINE 1: 2760003221743 4110 0 100000000005583 0 522760200562014 0 0 1...)
I have copied the lines to http://paste.lisp.org/display/39917
Best regards.
Franks is right
Please paste your command on a web site like http://paste.lisp.org/
then send us the url from it ;)
Frank Koormann a écrit :
> * Stefan Hahmann <s.hahmann at mapchart.com> [070418 12:06]:
>> Hi frank, david
>> Thank you for your help with the shapefile import. Switching off the
>> 32-bit option and changing the way the shp2pgsql | psql commands were
>> invoked did help.
>> But now another problem occured:
>> After i have successfully loaded data into my table _g24 using
>> shp2pgsql -s 4326 -c -I -D -k myshapefile1.shp public._g24 | psql -d
>> mapdata
>> I was not able to append data using
>> shp2pgsql -s 4326 -c -I -D -k myshapefile2.shp public._g24 | psql -d
>> mapdata
> If the above is your actual command line, you don't append data but
> try to overwrite existing data.
>> Although myshapefile1.shp and myshapefile2 do have the same structure.
> It would be helpful to get the get the first few lines from the first
> series of sql statements (up to and including the COPY line) and from
> the second series at least all up to the line cousing the error.
> Regards,
> Frank
___________________________________________________________________________
Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et son interface révolutionnaire.
http://fr.mail.yahoo.com
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
