[postgis-users] execute 'alter table' won't work
Peter Bange bange at argoss.nl
Wed Apr 18 05:15:36 PDT 2007
Hi Mark,
Thank you for your quick reply. I already had the 'raise notice' you
suggested in the code.
But what I found out now, is that when I drop all the code from 'end
loop' the code works fine ! So as a work around I have split the
routine in two parts ...., and that works. But this is rather
mysterious to me, but maybe clear for you.
Regards, Peter
The complete code is:
CREATE OR REPLACE FUNCTION afn_check_atb_comp1
   RETURNS text AS
$BODY$
--	INFO
--	This routine
--	1) checks if all pollutants described in atb_pollutants are
present as columns
--	in atb_compositions. If not, they will be added. Columns are never
dropped, so changing
--	a name in atb_pollutants will only result in adding a column.
--	2) updates all the 'others' fields when units are percentages
-- 	HISTORY
--	created bng april 2007
--	CALLED BY
DECLARE
	rec record;
	strSQL text;
	strFields text;
	strSep text;
	intStrange int;
BEGIN
--	Init
	strFields = '';
	strSep = '';
	for rec in select shortname from atb_pollutants loop
	--	loop over pollutants
		BEGIN
			if rec.shortname <> 'others' then
				strFields = strFields || strSep || rec.shortname;
				strSep = ' + ';
			end if;
			strSQL = 'alter table atb_compositions add column ' ||
rec.shortname || ' real';
			raise notice '%', strSQL;
			execute strSQL;
			raise notice '... added';
		EXCEPTION
			when duplicate_column then
			--	take next
			raise notice '... already existing';
		END;
	end loop;
	strSQL = 'update atb_compositions set others = 100 - (' || strFields
|| ') where units = ' || quote_literal('percentage');
	-- strSQL = 'update atb_compositions set others = 100 - (' ||
strFields || ') ';
	-- raise notice '%', strSQL;
	execute strSQL;
--	Check the percentages found
	strSQL = 'select count(*) from atb_compositions where units = ' ||
quote_literal('percentage') || ' and (others < 0 or others is null)';
	execute strSQL into intStrange;
	if intStrange = 1 then
		raise exception 'One percentage is not ok, check atb_compositions.';
		return '(Done with remarks)';
	elseif intStrange > 1 then
		raise exception '% percentages are not ok, check
atb_compositions.', trim(to_char(intStrange,'9999'));
	else
		return '(Done)';
	end if;
END
$BODY$
   LANGUAGE 'plpgsql';
> Hi Peter,
> Have you tried outputting the statement actually being executed, e.g.:
> rec.shortname ||
> ' real';
> raise notice 'sql: %', strSQL;
> execute strSQL;
> Also you haven't given the complete code for the stored procedure -
> for
> example, you may have specified incorrect variable types in the
> DECLARE
> section or incorrect parameter definitions in the function declaration
> itself.
> Kind regards,
> Mark.
> postgis-users mailing list
ARGOSS: your partner for atmospheric, marine & coastal information
P O Box 61
8325ZH Vollenhove The Netherlands
tel +31-527-242299 fax +31-527-242016
Web http://www.argoss.nl
Confidentiality Notice & Disclaimer
The contents of this e-mail and any attachments are intended only for
the
use of the e-mail addressee(s) shown. If you are not that person, or
one of
those persons, you are not allowed to take any action based upon it
or to
copy it, forward, distribute or disclose the contents of it and you
should
please delete it from your system.
ARGOSS Holding BV and its subsidiaries do not accept any liability
for any
errors or omissions in the context of this e-mail or its attachments
which
arise as a result of Internet transmission, nor accept liability for
statements which are those of the author and not clearly made on
behalf of
ARGOSS.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070418/72e6b36f/attachment.html>
