[postgis-users] Error installing PostGis
postgreadm at ibge.gov.br
Wed Apr 18 13:29:44 PDT 2007
I'm trying to install PostGis with GEOS and PROJ and I'm getting this
error when running make
/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/lwgeom_api.c:667:
relocation truncated to fit: R_390_GOT12 lwerror
lwgeom_api.o(.text+0x554): In function `lwgeom_getsubgeometry_inspected':
/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/lwgeom_api.c:1071:
lwgeom_api.o(.text+0x5f2): In function `printBOX3D':
/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/lwgeom_api.c:1590:
relocation truncated to fit: R_390_GOT12 lwnotice
lwgeom_api.o(.text+0x674): In function `printType':
/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/lwgeom_api.c:1685:
lwgeom_api.o(.text+0xa26): In function `printBYTES':
/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/lwgeom_api.c:1635:
lwgeom_api.o(.text+0xa8e):/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/lwgeom_api.c:1641:
lwgeom_api.o(.text+0xac2): In function `parse_lwgeom_wkt':
/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom/lwgeom_api.c:2167:
additional relocation overflows omitted from the output
collect2: ld returned 1 exit status
make[1]: *** [liblwgeom.so.1.0] Error 1
make[1]: Leaving directory
`/root/postgresql-8.1.4/contrib/postgis-1.0.6/lwgeom'
make: *** [liblwgeom] Error 2
lxpgtst:~/postgresql-8.1.4/contrib/postgis-1.0.6 #
We are using the following software versions:
z/Linux: SUSE Entreprise Edition SLES9 SP3
GEOS 2.1.4
Proj 4.5.0
PostGis 1.0.6
PostgreSQL 8.1.4
lxpgtst:~/postgresql-8.1.4/contrib/postgis-1.0.6 # make -v
GNU Make 3.80
lxpgtst:~/postgresql-8.1.4/contrib/postgis-1.0.6 # gcc -v
Reading specs from /usr/lib64/gcc-lib/s390x-suse-linux/3.3.3/specs
Configured with: ../configure --enable-threads=posix --prefix=/usr
--with-local-prefix=/usr/local --infodir=/usr/share/info
--mandir=/usr/share/man --enable-languages=c,c++,f77,objc,java,ada
--disable-checking --libdir=/usr/lib64 --enable-libgcj
--with-gxx-include-dir=/usr/include/g++ --with-slibdir=/lib64
--with-system-zlib --enable-shared --enable-__cxa_atexit s390x-suse-linux
Thread model: posix
gcc version 3.3.3 (SuSE Linux)
Any clue?
Thanks in advance.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070418/451199c2/attachment.html>
