[postgis-users] PostGIS command line options
Steffen Macke
sdteffen at gmail.com
Fri Apr 20 11:27:05 PDT 2007
Hi Leigh,
> to do the "SELECT postloading" and VACUUM ANALYZE from this same shell
> script that I have created? Any code would be greatly appreciated.
I'm not sure what "SELECT postloading" is. But you can issue
select statements and other statements from a shell using psql.
For example:
psql -c "VACUUM ANALYZE"
Note that most probably you'll have to add additional parameters
for user name, database, host, port, etc. See the PostgreSQL documentation
for this.
Regards,
Steffen
