[postgis-users] PostGIS command line options
Leigh Durland leighd at midwestsurveys.com
Fri Apr 20 11:45:48 PDT 2007
Thanks Steffen,
 I didn’t realize the postloading was actually a stored procedure, my mistake. But thanks for the tips that makes much more sense.
Greatly appreciated
Leigh
-----Original Message-----
Sent: April 20, 2007 12:27 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostGIS command line options
Hi Leigh,
> to do the "SELECT postloading" and VACUUM ANALYZE from this same shell
> script that I have created?  Any code would be greatly appreciated.
I'm not sure what "SELECT postloading" is. But you can issue
select statements and other statements from a shell using psql.
For example:
psql -c "VACUUM ANALYZE"
Note that most probably you'll have to add additional parameters
for user name, database, host, port, etc. See the PostgreSQL documentation
for this.
Regards,
Steffen
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
