[postgis-users] Connecting to postgis: localhost <-> dyndns:strange thing
Obe, Regina
robe.dnd at cityofboston.gov
Tue Apr 24 02:33:14 PDT 2007
This is really a postgresql question rather than a postgis I think.
Can you list out the tables you are getting in both cases. I'm sure the table that is different will give you a clue.
Also what driver/software are you using to connect? are you just connecting with psql command line or odbc or PgAdmin or something else? - it could be in your configuration that in one you have set to hide certain tables - e.g. in PgAdmin you can hide system tables and so forth.
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net on behalf of Steven De Vriendt
Sent: Tue 4/24/2007 5:24 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Connecting to postgis: localhost <-> dyndns:strange thing
I'm running a database on localhost. This database is reachable via a
dyndns-account.
I have a strange problem when I connect to my database via these parameters
host: localhost
port: 5432
passwd: *****
database: test
I get 4 tables, yet when I try to connect with my dyndns:
host: xxxxx.dyndns.org
port: 5432
passwd: *******
database: test
I get 5 tables ?
How is this possible, I'm running the database on the exact same pc ??
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070424/66221995/attachment.html>
