[postgis-users] Connecting to postgis: localhost <-> dyndns:strange thing
Obe, Regina robe.dnd at cityofboston.gov
Tue Apr 24 04:17:43 PDT 2007
This is highly unlikely I'm sure but I thought I would throw it out as a possibility.
You don't happen to have 2 PostgreSQL services running on your computer do you?
 - one possibly listening on ip: 127.0.0.2
and one listening on 192.168.2.2
and you have copies of the same database on both except slightly different.
If you check your postgresql.conf file - and look for listen_addresses it will tell you if it is listening on all Ips or just a specific one.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Steven De Vriendt
Sent: Tuesday, April 24, 2007 6:42 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Connecting to postgis: localhost <-> dyndns:strange thing
No luck...
I did change my windows hosts file like this:
127.0.0.1       localhost
192.168.2.2    ****.dyndns.org
altough I don't know if this has caused this...I'm a bit confused.
On 4/24/07, Barend Köbben <kobben at itc.nl> wrote:
> > I don't see the "missing" table in PgAdmin (localhost:5432)
> > Yet, when I use Mapserver
> Not even when you select the menu View > System Tables...?
> __
> Barend Köbben
> International Institute for Geo-information
> Sciences and Earth Observation (ITC)
> PO Box 6, 7500AA Enschede (The Netherlands)
> ph: +31 (0)53 4874253; fax: +31 (0)53 4874335
> postgis-users mailing list
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
