[postgis-users] overall bbox from some polygons
Obe, Regina robe.dnd at cityofboston.gov
Wed Apr 25 07:55:12 PDT 2007
Select extent(the_geom) from polygontable where oid in(....)
If your geometry is 3 dimensional, I think you need to use
extent3d.
Depending on how you are using this - to convert to a polygon with an
SRID, you may need to do
SELECT setsrid(extent(the_geom), <srid of your table goes here>) from
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Samson, Marko
Sent: Wednesday, April 25, 2007 10:34 AM
To: PostGIS Users Discussion
Subject: [postgis-users] overall bbox from some polygons
I want to get an overall-bbox of some polygons with a select statement.
With "select envelope(the_geom)from polygontable where oid in (.....)" I
just get the separate geoms of every single polygon. Now I'm looking for
a solution to get the bbox of all these polygons.
Is there a function or other elegant way to get the 'overall envelope'
of some polygons, or do I have to create a little sorting function into
my phpscript
Bye,
Marko
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
