[postgis-users] get and restore data via internet
Bruce Rindahl
rindahl at lrcwe.com
Wed Apr 25 15:58:19 PDT 2007
It is possible. I am putting together a SVG interface that gets data from a
PostGIS database and displays in a web browser. The user can modify the
shape, move , rotate, add delete vertices, etc. and then saved back to the
PostGIS database. All the code will be open but it is still a few months
away.
Bruce Rindahl
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Malm
Paul
Sent: Wednesday, April 25, 2007 8:30 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] get and restore data via internet
Well,k if you descide to play the piano, I would like to listen :-)
Kind Regards,
Paul
_____
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Pedro
Doria Meunier
Sent: den 25 april 2007 16:27
To: 'PostGIS Users Discussion'
Hey Paul,
As you can see I've misinterpreted your needs... :]
I'm not aware of any such solution without developing a custom one (like in
PHP/Ajax)
Perhaps our fellow 'listers' can shed some light into this matter. I, for
one, would like to know. :P
Since I'm a programmer to the bones my first instinct is to 'play the piano'
whereas quite often solutions are there for the taking. :D
Kind regards,
Pedro.
Paul
Sent: quarta-feira, 25 de Abril de 2007 15:04
Isn't Openjump a desktop application?
I don't want my visitors on my homepage to have to install any program but
the browser, if they want to add or change the geographical data.
Kind regards,
Paul
_____
Doria Meunier
Sent: den 25 april 2007 15:54
Hey Paul,
I might have misinterpreted your needs but...
Did you consider OpenJump? (http://www.openjump.org)
You can read and write from/to Postgresql/postgis databases (remote and
local) and save the layers to shapefiles.
HTH,
Pedro.
Paul
Sent: quarta-feira, 25 de Abril de 2007 10:22
Subject: [postgis-users] get and restore data via internet
Do anyone know of a sever applet that can get geographical data from Postgis
Database and save it as a shapefile on the local disc.
Then after update or adding data it should be possible to restore the data
in the PostGisDatabase over the internet.
Kind regards,
Paul
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070425/73b0b569/attachment.html>
