[postgis-users] RE: Distance function Trouble (Obe, Regina)
Paul Ramsey
pramsey at refractions.net
Wed Apr 25 22:39:01 PDT 2007
The correct SRID is 4326.
On 25-Apr-07, at 2:13 PM, I B Adams wrote:
> Okay, I have finally found some documentation on my data and it
> turns out that
> they are encoded using the wrong SRID,
> The details given are
> Projection: Geographic (not projected)
> Datum WGS84 (labeled GCS_WGS_1984 in ESRI products)
> Paramaters:
> • GEOGCS["GCS_WGS_1984",
> • DATUM["D_WGS_1984",
> • SPHEROID["WGS_1984",6378137,298.257223563]],
> • PRIMEM["Greenwich",0],
> • UNIT["Degree",0.017453292519943295]]
> I looked through the spatial_ref table and decided that the correct
> SRID would
> prob be 32601. So I used shp2pgsql to encode everything again.
> Added them all
> to the database etc. Now I do the distance again and get the exact
> same
> results.
> Have I still got the wrong SRID? What does (not projected) mean???
> postgis-users mailing list
