[postgis-users] Understanding distance calculation
Dmitri Maximovich maxim at md.pp.ru
Mon Apr 30 09:32:23 PDT 2007
Just started with PostGIS and have a (possibly naive) question about
calculating distance between two locations on the Earth surface.
Say I have two points with GPS coordinates: (44.397854 -79.5505) and
(44.37887 -79.688644). When I calculate distance between them in Google
map or Mappoint or any other tool I'm getting around 11.2 km, e.g.:
http://boulter.com/gps/distance/?from=44.397854+-79.5505&to=44.37887+-79.688644&units=k
When I'm trying to do the same in PostgreSql (8.0.12):
select distance_spheroid(
     GeomFromText('POINT(44.397854 -79.5505)', 4326),
     GeomFromText('POINT(44.37887 -79.688644)', 4326),
     'SPHEROID["WGS_1984",6378137,298.257223563]');
15429.5199451789
Should I interpret the result as 15.4 km? Obviously I'm doing something
wrong here. Any hint would be greatly appreciated. Thanks.
Sincerely,
Dmitri Maximovich
