[postgis-users] Retrieve all tables and views with geometry columns
Michael Fuhr
mike at fuhr.org
Wed Aug 1 03:59:58 PDT 2007
On Wed, Aug 01, 2007 at 11:42:15AM +0200, Boehm, Andreas wrote:
> I would like to list all the geometry columns in a database. So the user
> can select the features he or she wants to see. Therefore I need to
> retrieve the database's metadata.
> With "select * from geometry_columns" I'm able to get a list of all
> tables with geometry columns. But I don't get information about the
> _views_ with a geometry column.
> Do I have to parse the definition text in pg_views? Maybe there is an
> easier way...
You could query pg_catalog.pg_attribute or information_schema.columns.
http://www.postgresql.org/docs/8.2/interactive/catalog-pg-attribute.html
http://www.postgresql.org/docs/8.2/interactive/infoschema-columns.html
SELECT n.nspname, c.relname, a.attname
FROM pg_attribute AS a
JOIN pg_class AS c ON c.oid = a.attrelid
JOIN pg_namespace AS n ON n.oid = c.relnamespace
WHERE a.atttypid = 'geometry'::regtype
AND NOT a.attisdropped
AND c.relkind IN ('r', 'v')
ORDER BY n.nspname, c.relname, a.attname;
or
SELECT table_schema, table_name, column_name
FROM information_schema.columns
WHERE udt_name = 'geometry'
ORDER BY table_schema, table_name;
Michael Fuhr
