[postgis-users] problem with shp2pgsql / psql import
Michael Fuhr
mike at fuhr.org
Thu Aug 2 03:29:53 PDT 2007
On Tue, Jul 31, 2007 at 11:58:32AM +0200, Stefan Zweig wrote:
> i have attached an excerpt of the _g2793.sql which creates the
> table and imports one geometry row. maybe anybody can try importing
> this in his/her postgis and see whether postgis gives as well a
> null geometry after
> select id, name, astext(the_geom) from _g2793
Are you sure the geometry is null? What does the following query
return?
SELECT id, name, the_geom IS NULL, length(astext(the_geom)), summary(the_geom) FROM _g2793;
I get this:
id | name | ?column? | length | summary
632760049010583 | Saarland | f | 100818 |
: MultiPolygon[BS] with 1 elements
: Polygon[] with 1 rings
: ring 0 has 5294 points
(1 row)
What client are you using? I see the astext() output in psql but
not in pgAdmin, perhaps because the value is too long.
> i have no idea what is wrong with the INSERT statement. is there
> something like a geometry/WKT-validator?
Nothing is wrong with the statement as far as I can tell. Try psql
if you aren't using it already.
Michael Fuhr
