[postgis-users] ERROR: new row for relation "x" violates check constraint "enforce_geotype_the_geom"
Frank Koormann
frank.koormann at intevation.de
Thu Aug 9 03:04:02 PDT 2007
Hi again,
* Andreas Laggner <bloediandi at web.de> [070809 11:21]:
> i have to delete this constraint in EVERY table i want to write to! I
> think that is not normal?!
Partly - yes:
- AddGeometryColumn creates a contraint according to the geometry type
specified to be compliant with OGC.
- As a consequence you should first check the potential outcome of your
geomunion operation before creating the geomcolumn, you might run
something like:
select distinct(geometrytype(geomunion(t1.the_geom, t2.the_geom)))
from gf_veg1 t1, gf_veg2 t2
where t1.the_geom && t2.the_geom;
Regards,
Frank
Frank Koormann | ++49-541-335 08 30 | http://www.intevation.de/
Intevation GmbH, Georgstr. 4, 49074 Osnabrück, DE | AG Osnabrück, HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
