[postgis-users] Remove a geometry from a multi feature
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Aug 15 11:57:31 PDT 2007
Stephen Crawford wrote:
> All,
> I have a multipolygon feature that has 12 parts, a couple of which are
> "bad". How can I remove just these geometries and keep the rest as one
> multi feature? The bad ones are hundreds of miles away from the "good"
> ones, so I would like to do something like "remove all geomtries from
> feature x that are outside of bounding box (xy,xy)."
Basically you can not edit an existing object. The way to solve this
problem is to deconstruct the multipolygon in a set of polygons and
filter out the ones you want to exclude and then multi the remaining
objects back into a multipolygon and store it where ever.
-Steve W
