[postgis-users] Remove a geometry from a multi feature
Stephen Crawford src176 at psu.edu
Wed Aug 15 13:04:32 PDT 2007
Thanks, that worked very well.....broke it apart to a temp table, did a
COLLECT for the good features, and updated the original table.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
Woodbridge
Sent: Wednesday, August 15, 2007 2:58 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Remove a geometry from a multi feature
Stephen Crawford wrote:
> All,
> I have a multipolygon feature that has 12 parts, a couple of which are
> "bad".  How can I remove just these geometries and keep the rest as
> one multi feature?  The bad ones are hundreds of miles away from the
"good"
> ones, so I would like to do something like "remove all geomtries from
> feature x that are outside of bounding box (xy,xy)."
Basically you can not edit an existing object. The way to solve this problem
is to deconstruct the multipolygon in a set of polygons and filter out the
ones you want to exclude and then multi the remaining objects back into a
multipolygon and store it where ever.
-Steve W
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
