[postgis-users] import of Raster data
Andreas Laggner andreas.laggner at fal.de
Thu Aug 16 04:09:45 PDT 2007
Moin Stefan  ;-)
i want to use the spatial data from the raster together with vector data
in postgis. For example: soils from buk1000 and preception from DWD 1km
raster or altitude/slope from DEM25m raster to analyse potentials of
farmland.
I need the values from the cells in a spatial correct topology.
In the year 2007 the archive did not have any solutions for raster data
import.......
hasta luego      Andreas
Stephan Holl schrieb:
> Hello Andreas,
> Andreas Laggner <andreas.laggner at fal.de>, [20070816 - 10:43:36]
>> Moin PostGis users,
>> i want to import huge raster datasets from ArcGis Grid or Erdas
>> Imagine .img to PostGis (for example DEM25 meters germany around 16
>> million cells). What is the best way to do that? Found nothing in the
>> documentation that seems to be practical......(perhaps transform the
>> grid to points and import the points with the information of the
>> original cell size and the projection - but that seems to be
>> circuitous??).
> What are you going to achieve with that? Perhaps you could have a look
> at the archive of this list and search for raster data and so forth.
> There can be found an interesting dicussion about rasters and PostGIS.
> Best
> 	Stephan
Dipl. Geoökologe Andreas Laggner
Institut für Ländliche Räume (LR)
Bundesforschungsanstalt für Landwirtschaft (FAL)
Institute of Rural Studies
Federal Agricultural Research Centre (FAL)
Bundesallee 50
D-38116 Braunschweig
Tel.: (+49) (0)531 596 5515
Fax: (+49) (0)531 596 5599
E-mail: andreas.laggner at fal.de
Homepage: http://www.lr.fal.de/
