[postgis-users] Mac OS X installation problem - no "coveredby" in liblwgeom.1.3.so"
Webb Sprague webb.sprague at gmail.com
Sat Aug 18 09:01:19 PDT 2007
> I must confess I've never used the --with-libdir arguments to configure
> - I've always gone for explicit --with-pgsql, --with-geos, and
> --with-proj switches. If you check
> the /usr/local/postgis-1.3.1/share/lwpostgis.sql, does it contain the
> correct path to liblwgeom.1.3.so?
Yes, lwpostgis.sql contains the correct path - in fact, the previous
line of SQL  works just fine and finds liblwgeom for other functions.
It is only this line and subsequent that fails.
I intsalled geos right before building installing postgis.
tx
W
> ATB,
> Mark.
> ILande - Open Source Consultancy
> http://www.ilande.co.uk
> postgis-users mailing list
