[postgis-users] Mac OS X regression failures - 13/35 (was no "coveredby" in liblwgeom.1.3.so")
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Sun Aug 19 04:14:40 PDT 2007
On Sat, 2007-08-18 at 22:39 -0700, Webb Sprague wrote:
> Ok, never mind, I didn't know how to set my --with-geos flag correctly
> (though it is too bad that is built all the way then wouldn't work at
> run time).
> I get a bunch of regression errors which don't make any sense to me.
> Follows, though is the result of make test, and I can provide the
> diffs upon request. I am running SVN, so maybe I get what I deserve:
> PostgreSQL 8.2.4 on i386-apple-darwin8.10.1, compiled by GCC
> i686-apple-darwin8-gcc-4.0.1 (GCC) 4.0.1 (Apple Computer, Inc. build
> 5250)
> Postgis 1.3.2 - 2007-08-19 05:24:04
> GEOS: 3.0.0rc4-CAPI-1.3.3
> Running tests
> loader/Point.............. ok
> loader/PointM.............. ok
> loader/PointZ.............. ok
> loader/MultiPoint.............. ok
> loader/MultiPointM.............. ok
> loader/MultiPointZ.............. ok
> loader/Arc.............. ok
> loader/ArcM.............. ok
> loader/ArcZ.......... ok
> loader/Polygon.............. ok
> loader/PolygonM.............. ok
> loader/PolygonZ.............. ok
> regress. failed (diff expected obtained: /tmp/pgis_reg_494/test_13_diff)
> regress_index. ok
> regress_index_nulls. ok
> lwgeom_regress. ok
> regress_lrs. ok
> removepoint. failed (diff expected obtained: /tmp/pgis_reg_494/test_18_diff)
> setpoint. failed (diff expected obtained: /tmp/pgis_reg_494/test_19_diff)
> simplify. ok
> snaptogrid. ok
> affine. ok
> wkt. failed (diff expected obtained: /tmp/pgis_reg_494/test_23_diff)
> measures. ok
> long_xact. failed (diff expected obtained: /tmp/pgis_reg_494/test_25_diff)
> ctors. failed (diff expected obtained: /tmp/pgis_reg_494/test_26_diff)
> sql-mm-serialize. ok
> sql-mm-circularstring. failed (diff expected obtained:
> /tmp/pgis_reg_494/test_28_diff)
> sql-mm-compoundcurve. failed (diff expected obtained:
> /tmp/pgis_reg_494/test_29_diff)
> sql-mm-curvepoly. failed (diff expected obtained:
> /tmp/pgis_reg_494/test_30_diff)
> sql-mm-general. ok
> sql-mm-multicurve. failed (diff expected obtained:
> /tmp/pgis_reg_494/test_32_diff)
> sql-mm-multisurface. failed (diff expected obtained:
> /tmp/pgis_reg_494/test_33_diff)
> regress_ogc. failed (diff expected obtained: /tmp/pgis_reg_494/test_34_diff)
> regress_bdpoly. failed (diff expected obtained: /tmp/pgis_reg_494/test_35_diff)
> Run tests: 35
> Failed: 13
Well that's better :)
I'd tar.gz the /tmp/pgis_reg_494 directory, and if it's only a few 10s
of kB then post it to the postgis-devel list. Otherwise we have no way
of knowing what's broken ;)
ATB,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
