[postgis-users] Mac OS X regression failures - 13/35 (was no "coveredby" in liblwgeom.1.3.so")
Webb Sprague webb.sprague at gmail.com
Sun Aug 19 09:50:13 PDT 2007
Here is the tarred diff's from the tests that failed below (again, I
think - I am not sure about postgis regression tests)
Let me know if there are changes and I will rerun.
W
> > PostgreSQL 8.2.4 on i386-apple-darwin8.10.1, compiled by GCC
> > i686-apple-darwin8-gcc-4.0.1 (GCC) 4.0.1 (Apple Computer, Inc. build
> > 5250)
> >  Postgis 1.3.2 - 2007-08-19 05:24:04
> >    GEOS: 3.0.0rc4-CAPI-1.3.3
> > Running tests
> >  loader/Point.............. ok
> >  loader/PointM.............. ok
> >  loader/PointZ.............. ok
> >  loader/MultiPoint.............. ok
> >  loader/MultiPointM.............. ok
> >  loader/MultiPointZ.............. ok
> >  loader/Arc.............. ok
> >  loader/ArcM.............. ok
> >  loader/ArcZ.......... ok
> >  loader/Polygon.............. ok
> >  loader/PolygonM.............. ok
> >  loader/PolygonZ.............. ok
> >  regress. failed (diff expected obtained: /tmp/pgis_reg_494/test_13_diff)
> >  regress_index. ok
> >  regress_index_nulls. ok
> >  lwgeom_regress. ok
> >  regress_lrs. ok
> >  removepoint. failed (diff expected obtained: /tmp/pgis_reg_494/test_18_diff)
> >  setpoint. failed (diff expected obtained: /tmp/pgis_reg_494/test_19_diff)
> >  simplify. ok
> >  snaptogrid. ok
> >  affine. ok
> >  wkt. failed (diff expected obtained: /tmp/pgis_reg_494/test_23_diff)
> >  measures. ok
> >  long_xact. failed (diff expected obtained: /tmp/pgis_reg_494/test_25_diff)
> >  ctors. failed (diff expected obtained: /tmp/pgis_reg_494/test_26_diff)
> >  sql-mm-serialize. ok
> >  sql-mm-circularstring. failed (diff expected obtained:
> > /tmp/pgis_reg_494/test_28_diff)
> >  sql-mm-compoundcurve. failed (diff expected obtained:
> > /tmp/pgis_reg_494/test_29_diff)
> >  sql-mm-curvepoly. failed (diff expected obtained:
> > /tmp/pgis_reg_494/test_30_diff)
> >  sql-mm-general. ok
> >  sql-mm-multicurve. failed (diff expected obtained:
> > /tmp/pgis_reg_494/test_32_diff)
> >  sql-mm-multisurface. failed (diff expected obtained:
> > /tmp/pgis_reg_494/test_33_diff)
> >  regress_ogc. failed (diff expected obtained: /tmp/pgis_reg_494/test_34_diff)
> >  regress_bdpoly. failed (diff expected obtained: /tmp/pgis_reg_494/test_35_diff)
> > Run tests: 35
> > Failed: 13
Type: application/x-gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070819/33b123db/attachment.bin>
