[postgis-users] Mac OS X regression failures - 13/35 (was no "coveredby" in liblwgeom.1.3.so")
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Tue Aug 21 16:23:07 PDT 2007
On Sun, 2007-08-19 at 09:50 -0700, Webb Sprague wrote:
> Here is the tarred diff's from the tests that failed below (again, I
> think - I am not sure about postgis regression tests)
> Let me know if there are changes and I will rerun.
> W
Strange... I'm having trouble understanding those diff formats. Could
you try something else - in the regress/ subdirectory, comment out line
139 in the file run_test which states: rm "${OUTFILE}" # diff is enough
and then re-run the regression tests and zip up the directory contents
again?
Note that I only need the directory from the current run, i.e. only
one /tmp/pgis_reg_* directory which will contain the diffs for the last
run - the regression output will tell you which is the correct number
for the last run.
Many thanks,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
