[postgis-users] Mac OS X regression failures - 13/35 (was no "coveredby" in liblwgeom.1.3.so")
Webb Sprague
webb.sprague at gmail.com
Tue Aug 21 17:51:07 PDT 2007
> Strange... I'm having trouble understanding those diff formats. Could
> you try something else - in the regress/ subdirectory, comment out line
> 139 in the file run_test which states: rm "${OUTFILE}" # diff is enough
> and then re-run the regression tests and zip up the directory contents
> again?
> Note that I only need the directory from the current run, i.e. only
> one /tmp/pgis_reg_* directory which will contain the diffs for the last
> run - the regression output will tell you which is the correct number
> for the last run.
Voila. Let me know if there is any way I can help.
-W
Type: application/x-gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070821/dc15876e/attachment.bin>
