[postgis-users] can't run lwpostgis
Obe, Regina
robe.dnd at cityofboston.gov
Mon Aug 20 06:01:36 PDT 2007
Ryan,
lwpostgis_upgrade.sql is in the \share\contrib\postgis folder not the \share\contrib folder. It looks like from your path you were in just the contrib folder.
try cding into postgis folder after launching the PostgreSQL command prompt and then give it another go.
alternatively just do
psql -f "C:\Program Files\PostgreSQL\8.2\share\contrib\postgis\lwpostgis_upgrade.sql" -d il_voter_1
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net on behalf of Mark Cave-Ayland
Sent: Mon 8/20/2007 2:28 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] can't run lwpostgis
On Sun, 2007-08-19 at 12:31 -0700, Ryan D. Enos wrote:
> Thanks Mark, I was hoping it would be that simple, but I am still getting the same error:
> //lwpostgis_upgrade.sql: No such file or directory//
> any other suggestions?
> thanks.
> Ryan
Hmmm, do the file permissions look reasonable for the
lwpostgis_upgrade.sql file? Other than that, I don't think I can help
you as I'm still using WinXP and have never really used Vista - all I
can tell you is that the installer doesn't explicitly change any file
permissions when extracting the files :(
ATB,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk <http://www.ilande.co.uk/>
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070820/6bae91f9/attachment.html>
