[postgis-users] Calculating bbox/extent for set of polygons: ERROR I don't understand
matt.pettis at thomson.com matt.pettis at thomson.com
Mon Aug 20 14:29:21 PDT 2007
Thanks Josh,
This did the trick.
Matt
It is from the wellspring of our despair and the places that we are
broken that we come to repair the world.
-- Murray Waas
I don't know the intricacies of that error, but you have a couple easy
options.  For just the one county, like in your query - ditch the
distinct, eg:
SELECT extent(the_geom) FROM shp_precincts WHERE county_id=72;
For all counties, try pulling the geom data out in different style, eg:
SELECT distinct(county_id), astext(extent(the_geom)) as the_extent FROM
shp_precincts GROUP BY county_id
 -Josh
Matthew Pettis wrote:
> Hi,
> I'm trying to calculate a minimum bbox/extent for a group of polygons
> with a similar attribute.  For this specific case, I am trying to find
> a bbox/extent for all of the voting precincts within the same county.
> here is the sql I'm executing:
> select
> distinct
>     extent(the_geom) as the_extent
> from
>     shp_precincts
> where
>     county_id = 72
> 'the_geom' is a polygon representing a voting precinct, and the where
> clause subsets to all voting precincts belonging to a specific
> county.  I get the following error which I don't understand or know
> how to correct:
> ERROR:  could not identify an ordering operator for type box2d
> HINT:  Use an explicit ordering operator or modify the query.
> Any help is appreciated in resolving this.  What I ultimately want to
> do is have a result set that has a bounding box for each county based
> on the polygons of precincts that belong to that county.
> tia,
> Matt
> -- Murray Waas
> postgis-users mailing list
<http://postgis.refractions.net/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070820/d61a8391/attachment.html>
