[postgis-users] Help finding information on creating a "Heat Map"
Jeff Hoffmann jeff at propertykey.com
Fri Aug 24 08:57:24 PDT 2007
Woody Woodring wrote:
>  Thanks for the info, but I had looked at theses earlier.  They require that
> I ship the data to them, which is out of the question due to size and
> confidentiality agreements.
> I was looking to do the work in-house, more so that I could learn something
> in the process.
It's kind of a simple concept once you figure it out, although I'm not
really familiar with any pre-existing packages specifically for GIS type
of work.  There are a few people that have packages to do heat maps for
click locations on web pages, you could probably adapt that pretty
easily -- especially if you were doing, say, MapServer/PHP mapscript.
For example, http://www.labsmedia.com/clickheat/index.html has PHP
source to do it for web pages, but the heat map generating is in its own
class and can be used separately.
Jeff Hoffmann
Head Plate Spinner
PropertyKey.com
