[postgis-users] connection terminated with buffer(0.0)
Andreas Laggner andreas.laggner at fal.de
Tue Aug 28 05:16:02 PDT 2007
Hello,
i used buffer(the_geom, 0.0) several times to repair geometry and it
works good. But now i have a dataset, where problems occur: Any time i
try to repair with buffer the connection to postgresql is terminated. It
seems to relate to one (or more) bad geometry. What can i do now?
My statement (the most simple one without attributes to minimize
possible sources for errors):
create table gemeinden_rep();
select
addgeometrycolumn('','gemeinden_rep','the_geom','31467','MULTIPOLYGON',2);
alter table gemeinden_rep drop constraint enforce_geotype_the_geom;
insert into gemeinden_rep
    select buffer(the_geom, 0.0)
    from gemeinden;
Thanks      Andreas
Dipl. Geoökologe Andreas Laggner
Institut für Ländliche Räume (LR)
Bundesforschungsanstalt für Landwirtschaft (FAL)
Institute of Rural Studies
Federal Agricultural Research Centre (FAL)
Bundesallee 50
D-38116 Braunschweig
Tel.: (+49) (0)531 596 5515
Fax: (+49) (0)531 596 5599
E-mail: andreas.laggner at fal.de
Homepage: http://www.lr.fal.de/
