[postgis-users] connection terminated with buffer(0.0)
Paul Ramsey pramsey at refractions.net
Tue Aug 28 07:35:53 PDT 2007
Figure out which geometry is the problem one so (a) you can work
around it and (b) you can attach it to a bug report and (c) we can
eventually fix it.
Worst case scenario, binary search by repeatedly cutting your input
data set in half.
P
On 28-Aug-07, at 5:16 AM, Andreas Laggner wrote:
> Hello,
> i used buffer(the_geom, 0.0) several times to repair geometry and
> it works good. But now i have a dataset, where problems occur: Any
> time i try to repair with buffer the connection to postgresql is
> terminated. It seems to relate to one (or more) bad geometry. What
> can i do now?
> My statement (the most simple one without attributes to minimize
> possible sources for errors):
> create table gemeinden_rep();
> select addgeometrycolumn
> ('','gemeinden_rep','the_geom','31467','MULTIPOLYGON',2);
> alter table gemeinden_rep drop constraint enforce_geotype_the_geom;
> insert into gemeinden_rep
>    select buffer(the_geom, 0.0)
>    from gemeinden;
> Thanks      Andreas
> Dipl. Geoökologe Andreas Laggner
> Institut für Ländliche Räume (LR)
> Bundesforschungsanstalt für Landwirtschaft (FAL)
> Institute of Rural Studies
> Federal Agricultural Research Centre (FAL)
> Bundesallee 50
> D-38116 Braunschweig
> Tel.: (+49) (0)531 596 5515
> Fax: (+49) (0)531 596 5599
> E-mail: andreas.laggner at fal.de
> Homepage: http://www.lr.fal.de/
> postgis-users mailing list
