[postgis-users] Union of 7 datasets
Andreas Laggner
andreas.laggner at fal.de
Tue Aug 28 06:12:48 PDT 2007
Obe, Regina schrieb:
> Sounds like you would have to go with a full join type thing with workaround I described below (last example). So If I understand you correctly then something like this -
> --the first select gives you those records in both tables your 25 udokai
> SELECT udo.field1, udo.field2, kai.field3, kai.field4, geomunion(udo.the_geom, kai.the_geom) AS newgeom
> FROM udo INNER JOIN kai ON (udo.the_geom && kai.the_geom AND intersects(udo.the_geom, kai.the_geom))
> UNION
> -- the second select gives you udos that have no kais - your 15
> SELECT udo.field1, udo.field2, NULL As field3, NULL As field4, udo.the_geom AS newgeom
> FROM udo LEFT JOIN kai ON (udo.the_geom && kai.the_geom AND intersects(udo.the_geom, kai.the_geom))
> WHERE kai.the_geom IS NULL
> UNION
> -- and the 3rd gives you kais that have no udos. - your 40
> SELECT nul As field1, null As field2, kai.field3, kai.field4, kai.the_geom AS newgeom
> FROM kai LEFT JOIN udo ON (udo.the_geom && kai.the_geom AND intersects(udo.the_geom, kai.the_geom))
> WHERE udo.the_geom IS NULL
> Unioned together you should get
> 25 + 15 + 40 = ? 80
> Hope that helps,
> Regina
UFF - that seems to be a complex question, a comprehensive operation and
a lot to type too!!! Thanks a million - i would have spent many time to
find out this query by myself! Ok..... how can i perform your "UNION": I
would just insert my selects one after another in one new table - will
that work well?
I want to aggregate around 20 datasets this way!? Do you know a method
to operate with more datasets (for example 7) in a effektiv manner and
not to do this three selects 6 times?
AND: Am i totally wrong with my aims? It seems to me that is an exotic
think to do with PostGis, but our projects/problems require to aggregate
datasets in almost all cases (around 90%) and that is exactly what one
of the basic functions "Union" in ArcView already carried out ten years
ago. So i would exspect there is a function to perform this operation
easier!? .....i just wonder.....
cheers Andreas
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Andreas Laggner
> Sent: Tuesday, August 28, 2007 7:28 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Union of 7 datasets
>> BASIC TRICK: If you want to get all records with no matching including those that match - put what you would normally put in your WHERE clause in the JOIN clause and use a LEFT JOIN.
> ok - it seems to me i need some coaching......Yes, I want to get all
> records with no matching including those that match, but i also want to
> dissect the polygons that matches. I will try to explain again just to
> be sure you understood my aims: I have 20 polygons in udo and 50 in kai.
> 10 from kai are intersecting 5 from udo to 25 new polygons i call udokai
> (because they have attributes from udo AND kai). My result should have:
> 15 polygons with attributes only from udo, 40 polygons with attributes
> only from kai AND 25 with attributes from udo and kai! In most cases i
> want to do such a operation because i want to aggregate (spatial
> correct) different datasets!
> Which example from you fits best for this aim? I did not find any
> information on how left join works on the postgis or postgresql reference...
>> Unfortunately as I have come across before if you need an either or (if in table 1 or table 2 - ideally you would use a FULL JOIN but for some reason Postgres chokes when you use postgis functions in the FULL JOIN clause for the cases I have tried). In that case you need a workaround using a set of UNIONS.
>> Simplest case - get all records in g1 one or union of g1 and g2 that intersect
>> NOTE: COALESCE is an ANSI SQL function that will return the first non-null - when you do a geomunion of a geometry and null you get null which is why we need COALESCE
>> SELECT g1.field1, g1.field2, COALESCE(geomunion(g1.the_geom, g2.the_geom), g1.the_geom) AS newgeom
>> FROM g1 LEFT JOIN g2 ON (g1.the_geom && g2.the_geom AND intersects(g1.the_geom, g2.the_geom))
>> Either of case - get all geometries in g1 or g2 or union if there is a match - workaround for full joins not working right
>> SELECT g1.field1, g1.field2, geomunion(g1.the_geom, g2.the_geom) AS newgeom
>> FROM g1 INNER JOIN g2 ON (g1.the_geom && g2.the_geom AND intersects(g1.the_geom, g2.the_geom))
>> UNION
>> SELECT g1.field1, g1.field2, g1.the_geom AS newgeom
>> WHERE g2.the_geom IS NULL
>> UNION
>> SELECT g1.field1, g1.field2, g2.the_geom AS newgeom
>> FROM g2 LEFT JOIN g1 ON (g1.the_geom && g2.the_geom AND intersects(g1.the_geom, g2.the_geom))
>> WHERE g1.the_geom IS NULL
>> Hope that helps,
>> Regina
>> Sent: Thursday, August 23, 2007 11:32 AM
>>> Oh the g1 g2 .. was just for example - I don't actually call my tables meaningless names like that.
>>> You should be doing a join on something or have a where clause unless one of your tables has only one record. Otherwise you are doing what is called a CROSS JOIN (cartesian product) which gives you an nxm records where n is the number of records in your first table and m is the number in second table. This is generally a big NO NO. In certain rare cases you do want to do something like that, but is usually the exception.
>> I think the records in my targed table must be added (more or less) and
>> not multiplied! My Aim is a table that contains the areas of all the 7
>> sourcetables and the information which refuges are inside and wich not.
>> Perhaps i must use the intersection!? If i do my query with a gist like
>> this: where t1.the_geom && t2.the_geom; than the operation is very fast
>> (about one minute) but i only have the Polygons covered by BOTH
>> datasets, and i want to have as well those, which are covered by one
>> dataset only!! But my operation without the where clause runs for 4
>> hours now - that shows me there is something wrong ;-)
>>> Its hard for me to tell if you need a cartesian product in this case since I'm not quite sure what for example nature and biosphere represent. I would guess that is wrong and you should first figure out which sets of say nature records you need to geomunion with biosphere and then join by that field or set of fields.
>>> It would help a bit if you could provide some sample questions you expect to answer with your statistical analysis. My guess is you may be better off with more than one table.
>> Sample question: give me all areas (all polygons) from germany where
>> landuse=arable land and soils=good and precipitation>600 and any (of 7)
>> reserves and so on.......
>> I need the values in my table to calculate the potential yield or other
>> things...
>> And i want to analyse such questions with a statistical software (SAS),
>> so it seems to me i need one table to import in SAS (or to query from
>> SAS directly to the postgresql).
>> Thanks for your help, i will be back in my office in Monday.......Andreas
>>> Which structure is best really boils down to what questions you hope to answer because one approach may make one question easy and fast and another question slow and cumbersome.
>>> Hope that helps,
>>> Regina
>>> Sent: Thursday, August 23, 2007 10:04 AM
>>>> Andreas,
>>>> It would help to know what your table structure looks like and why do you want to put them all in a single geometry?
>>> My table structures are a little bit different. I want to have them in a
>>> single geometry to intersect them with other data and built a large
>>> table to run statistics over it (production site analysis over germany).
>>>> I'm imaging you are you doing something like
>>>> SELECT g1.somefield, geomunion(geomunion(g1.the_geom, g2.the_geom), g3.the_geom)
>>>> FROM g1 INNER JOIN g2 on g1.somefield = g2.somefield INNER JOIN g3 on g2.somefield = g3.somefield
>>>> GROUP BY g1.somefield
>>> That´s an interesting method with inner join..why go you call your
>>> tables g1. g2. and so on?
>>> That´s my method i am using right now (geomunion 1 to 3 from 6), seems
>>> to be a pedestrian method :-(
>>> create table natura2000
>>> (ffh_name character varying(80), ffh_land character varying(3), ffh
>>> smallint, ffh_id smallint,
>>> spa_name character varying(80), spa_land character varying(3), spa
>>> smallint, spa_id smallint) with oids;
>>> select
>>> addgeometrycolumn('','natura2000','the_geom','31467','MULTIPOLYGON',2);
>>> alter table natura2000 drop constraint enforce_geotype_the_geom;
>>> insert into natura2000
>>> select
>>> t1.ffh_name,t1.ffh_land,t1.ffh,t1.ffh_id,t2.spa_name,t2.spa_land,t2.spa,t2.spa_id,
>>> geomunion(t1.the_geom, t2.the_geom)
>>> from ffh_rep t1, spa_rep t2;
>>> create table sg71
>>> smallint, spa_id smallint,
>>> bio_name character varying(70), bio smallint, bio_id smallint) with
>>> oids;
>>> select addgeometrycolumn('','sg71','the_geom','31467','MULTIPOLYGON',2);
>>> alter table sg71 drop constraint enforce_geotype_the_geom;
>>> insert into sg71
>>> select t1.ffh_name, t1.ffh_land, t1.ffh, t1.ffh_id, t1.spa_name,
>>> t1.spa_land, t1.spa, t1.spa_id,
>>> t2.name,t2.bio,t2.bio_id,geomunion(t1.the_geom, t2.the_geom)
>>> from natura2000 t1, biosphere t2;
>>> create table sg72
>>> ffh smallint, ffh_id smallint,
>>> bio_name character varying(70), bio smallint, bio_id smallint,
>>> np_name character varying(60), np smallint, np_id smallint) with oids;
>>> select addgeometrycolumn('','sg72','the_geom','31467','MULTIPOLYGON',2);
>>> alter table sg72 drop constraint enforce_geotype_the_geom;
>>> insert into sg72
>>> t1.bio_name,t1.bio,t1.bio_id,t2.np_name,t2.np,t2.np_id,
>>> from sg71 t1, np t2;
>>> AND SO ON......
>>>> or
>>>> SELECT g1.somefield, geomunion(gt.the_geom)
>>>> FROM (SELECT somefield, the_geom FROM g1 UNION SELECT somefield, the_geom FROM g2 ...) gt
>>>> GROUP BY gt.somefield
>>>> If I have 7 different tables that have pretty much the same structure, but for logistical or other technical reasons (such as each has additional attributes distinct from one another), I need to keep them as separate tables, then I usually use inherited tables for that. That way when I need to join all datasets at once, I can simply query the parent table and it will automatically drill down to the child tables. Not sure if that helps more than it confuses your situation.
>>>> Then instead of the above I can simply do
>>>> SELEG myparenttable.somefield, geomunion(myparenttable.the_geom)
>>>> FROM myparenttable
>>>> GROUP by gh.somefield
>>> ok - i have to think about your suggestions......that´s my second week
>>> with postgis.
>>> Can you tell me from my SQL-Statements which method will be best? So i
>>> try to understand that one.....
>>> Thanks for your reply!!!
>>>> Hope that helps,
>>>> Regina
>>>> Sent: Thursday, August 23, 2007 9:11 AM
>>>> To: PostGis_Mailinglist
>>>> Subject: [postgis-users] Union of 7 datasets
>>>> Hi users,
>>>> i want to put together 7 datasets to have all the different refuges in
>>>> one table (and in one geometry). Am i doing right with 6 times geomunion
>>>> (that´s much to type with all the attributes) or is there a more
>>>> effective way?
>>>> cheers Andreas
Dipl. Geoökologe Andreas Laggner
Institut für Ländliche Räume (LR)
Bundesforschungsanstalt für Landwirtschaft (FAL)
Institute of Rural Studies
Federal Agricultural Research Centre (FAL)
Bundesallee 50
D-38116 Braunschweig
Tel.: (+49) (0)531 596 5515
Fax: (+49) (0)531 596 5599
E-mail: andreas.laggner at fal.de
Homepage: http://www.lr.fal.de/
