[postgis-users] Building PostGis with VC++
Charlie Savage
cfis at savagexi.com
Tue Aug 28 19:41:19 PDT 2007
> I'm not clear why it is bad to mess with another DLL's memory. I
> thought it
> was just dangerous to try and free memory allocated by another DLL
(as they
> may have distinct heaps). If that is the case, it should be fine to use
> pj_get_errno_ref() to get a pointer to the pj_errno in the PROJ DLL and
> work by reference through that pointer.
> Best regards,
Some enlightenment from
http://www.cygwin.com/ml/cygwin/1999-12/msg00043.html (and verified in a
couple of other posts I've come across).
The situation is sadly different for variables. An
extern variable, v, used in a client and defined in a
DLL must be declared like this in every client source
file that uses it:
__declspec (dllimport) extern int v;
So I'll use the function - otherwise it will require some ugly
dllimport/dllexport gymnastics depending on who is reusing the proj
header files.
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070828/af7bed39/attachment.bin>
