[postgis-users] MSVC Patch #1
Charlie Savage
cfis at savagexi.com
Tue Aug 28 22:22:21 PDT 2007
I've divided up the MSVC++ patch into two parts. This is the
interesting part - it includes the change needed to the current PostGis
code base plus the addition of a file config.h.vc.
The most debatable part of the patch are changes to lex.yy.c since I'm
sure its autogenerated. The problem is that it includes a reference too
unistd.h. Taking out for MSVC++ doesn't seem to break anything -
suppose we could just stub out that file for MSVC++.
The second patch is much bigger and much less interesting - thus I
haven't included it. It contains the MSVC++ project files and the extra
files required that don't exist on Windows (inttypes.h, stdint.h, and a
rint implementation).
Only in .: build
Only in .: config.h
Only in .: config.h.vc
Only in ./java/ejb2: lib
diff -u -r /c/temp/postgis-1.3.1/loader/pgsql2shp.c ./loader/pgsql2shp.c
--- /c/temp/postgis-1.3.1/loader/pgsql2shp.c 2007-08-28 21:25:32 -0600
+++ ./loader/pgsql2shp.c 2007-08-28 22:04:23 -0600
@@ -34,8 +34,18 @@
#include "shapefil.h"
#include "getopt.h"
#include "compat.h"
+#include "../config.h"
+#ifdef _MSC_VER
+#include <process.h> // for getpid()
+#include <windows.h> // for lstrcmpi
+#define snprintf _snprintf
+#define strcasecmp lstrcmpi
+#define strncasecmp strnicmp
+#else
#include <sys/types.h> // for getpid()
#include <unistd.h> // for getpid()
+#endif
#ifdef __CYGWIN__
#include <sys/param.h>
@@ -2333,12 +2343,13 @@
int
parse_commandline(int ARGC, char **ARGV)
+ int c, curindex;
+ char buf[1024];
if ( ARGC == 1 ) {
usage(ARGV[0], 0, stdout);
- int c, curindex;
- char buf[1024];
buf[1023] = '\0'; /* just in case... */
Only in ./loader: pgsql2shp.exe
diff -u -r /c/temp/postgis-1.3.1/loader/shp2pgsql.c ./loader/shp2pgsql.c
--- /c/temp/postgis-1.3.1/loader/shp2pgsql.c 2007-08-28 21:25:32 -0600
+++ ./loader/shp2pgsql.c 2007-08-28 21:24:59 -0600
@@ -30,7 +30,11 @@
#include <ctype.h>
#include <sys/stat.h>
+#ifdef _MSC_VER
+#else
#include <unistd.h>
+#endif
#include <errno.h>
#include "getopt.h"
#ifdef HAVE_ICONV_H
Only in ./loader: shp2pgsql.exe
diff -u -r /c/temp/postgis-1.3.1/lwgeom/lex.yy.c ./lwgeom/lex.yy.c
--- /c/temp/postgis-1.3.1/lwgeom/lex.yy.c 2007-08-28 21:25:32 -0600
+++ ./lwgeom/lex.yy.c 2007-08-28 22:18:09 -0600
@@ -28,7 +28,9 @@
#define YY_FLEX_MINOR_VERSION 5
#include <stdio.h>
+#ifndef _MSC_VER
#include <unistd.h>
+#endif
/* cfront 1.2 defines "c_plusplus" instead of "__cplusplus" */
@@ -3264,7 +3266,9 @@
#line 11 "wktparse.lex"
#include "wktparse.tab.h"
+#ifndef _MSC_VER
#include <unistd.h>
+#endif
#include <stdlib.h> // need stdlib for atof() definition
void init_parser(const char *src);
Only in ./lwgeom: liblwgeom.a
Only in ./lwgeom: liblwgeom.dll
diff -u -r /c/temp/postgis-1.3.1/lwgeom/liblwgeom.h ./lwgeom/liblwgeom.h
--- /c/temp/postgis-1.3.1/lwgeom/liblwgeom.h 2007-08-28 21:25:36 -0600
+++ ./lwgeom/liblwgeom.h 2007-08-28 21:24:56 -0600
@@ -3,6 +3,7 @@
#include <stdio.h>
#include "compat.h"
#define INTEGRITY_CHECKS 1
/* #define DEBUG_ALLOCS 1 */
diff -u -r /c/temp/postgis-1.3.1/lwgeom/lwcurve.c ./lwgeom/lwcurve.c
--- /c/temp/postgis-1.3.1/lwgeom/lwcurve.c 2007-08-28 21:25:32 -0600
+++ ./lwgeom/lwcurve.c 2007-08-28 21:24:59 -0600
@@ -22,7 +22,7 @@
/*#define PGIS_DEBUG 1 */
#ifndef MAXFLOAT
- #define MAXFLOAT 3.40282347e+38F
+ #define MAXFLOAT 3.402823466e+38F
#endif
@@ -32,6 +32,8 @@
LWCURVE *
lwcurve_construct(int SRID, BOX2DFLOAT4 *bbox, POINTARRAY *points)
+ LWCURVE *result;
* The first arc requires three points. Each additional
* arc requires two more points. Thus the minimum point count
@@ -43,7 +45,6 @@
return NULL;
- LWCURVE *result;
result = (LWCURVE*) lwalloc(sizeof(LWCURVE));
result->type = lwgeom_makeType_full(
Only in ./lwgeom: lwgeom.def
diff -u -r /c/temp/postgis-1.3.1/lwgeom/lwgeom_dump.c ./lwgeom/lwgeom_dump.c
--- /c/temp/postgis-1.3.1/lwgeom/lwgeom_dump.c 2007-08-28 21:25:32 -0600
+++ ./lwgeom/lwgeom_dump.c 2007-08-28 21:24:59 -0600
@@ -272,6 +272,7 @@
LWPOLY* poly = state->poly;
POINTARRAY *ring;
+ LWGEOM* ringgeom;
/* Switch to an appropriate memory context for POINTARRAY
* cloning and hexwkb allocation */
@@ -281,7 +282,7 @@
ring = ptarray_clone(poly->rings[state->ringnum]);
/* Construct another polygon with shell only */
- LWGEOM* ringgeom = (LWGEOM*)lwpoly_construct(
+ ringgeom = (LWGEOM*)lwpoly_construct(
poly->SRID,
NULL, /* TODO: could use input bounding box here */
1, /* one ring */
diff -u -r /c/temp/postgis-1.3.1/lwgeom/lwgeom_rtree.c
./lwgeom/lwgeom_rtree.c
--- /c/temp/postgis-1.3.1/lwgeom/lwgeom_rtree.c 2007-08-28 21:25:32 -0600
+++ ./lwgeom/lwgeom_rtree.c 2007-08-28 21:24:59 -0600
@@ -21,7 +21,8 @@
RTREE_NODE *createTree(POINTARRAY *pointArray)
RTREE_NODE *root;
- RTREE_NODE *nodes[pointArray->npoints];
+ RTREE_NODE** nodes = palloc(sizeof(RTREE_NODE*) *
pointArray->npoints);
int i, nodeCount;
int childNodes, parentNodes;
@@ -81,6 +82,7 @@
#ifdef PGIS_DEBUG
lwnotice("createTree returning %p", root);
#endif
+ free(nodes);
return root;
diff -u -r /c/temp/postgis-1.3.1/lwgeom/lwgeom_transform.c
./lwgeom/lwgeom_transform.c
--- /c/temp/postgis-1.3.1/lwgeom/lwgeom_transform.c 2007-08-28 21:25:32
-0600
+++ ./lwgeom/lwgeom_transform.c 2007-08-28 21:24:59 -0600
@@ -427,6 +427,7 @@
PJ *projection = NULL;
char *proj_str;
char proj4_spi_buffer[256];
+ int* pj_errno_ref;
/* Connect */
spi_result = SPI_connect();
@@ -452,11 +453,12 @@
strcpy(proj_str, SPI_getvalue(tuple, tupdesc, 1));
projection = make_project(proj_str);
- if ( (projection == NULL) || pj_errno)
+ pj_errno_ref = pj_get_errno_ref();
+ if ( (projection == NULL) || (*pj_errno_ref))
/* we need this for error reporting */
/*pfree(projection); */
- elog(ERROR, "AddToPROJ4SRSCache: couldn't parse proj4 string: '%s':
%s", proj_str, pj_strerrno(pj_errno));
+ elog(ERROR, "AddToPROJ4SRSCache: couldn't parse proj4 string: '%s':
%s", proj_str, pj_strerrno(*pj_errno_ref));
@@ -571,7 +573,7 @@
long i;
/*int need_datum_shift; */
- pj_errno = 0;
if( point_offset == 0 )
point_offset = 1;
@@ -587,8 +589,10 @@
projected_loc.v = y[point_offset*i];
geodetic_loc = pj_inv( projected_loc, srcdefn );
- if( pj_errno != 0 )
- return pj_errno;
+ if( (*pj_errno_ref) != 0 )
+ return *pj_errno_ref;
x[point_offset*i] = geodetic_loc.u;
y[point_offset*i] = geodetic_loc.v;
@@ -606,8 +610,10 @@
geodetic_loc.v = y[point_offset*i];
projected_loc = pj_fwd( geodetic_loc, dstdefn );
- return pj_errno;
x[point_offset*i] = projected_loc.u;
y[point_offset*i] = projected_loc.v;
@@ -910,6 +916,7 @@
text *output_proj4_text;
int32 result_srid ;
uchar *srl;
result_srid = PG_GETARG_INT32(3);
if (result_srid == -1)
@@ -941,26 +948,30 @@
/* make input and output projection objects */
input_pj = make_project(input_proj4);
- if ( (input_pj == NULL) || pj_errno)
+ if ( (input_pj == NULL) || (*pj_errno_ref))
/* pfree(input_proj4); */
pfree(output_proj4);
pfree(geom);
- elog(ERROR, "transform: couldn't parse proj4 input string: '%s': %s",
input_proj4, pj_strerrno(pj_errno));
+ elog(ERROR, "transform: couldn't parse proj4 input string: '%s': %s",
input_proj4, pj_strerrno(*pj_errno_ref));
PG_RETURN_NULL();
pfree(input_proj4);
output_pj = make_project(output_proj4);
- if ((output_pj == NULL)|| pj_errno)
+ if ((output_pj == NULL)|| (*pj_errno_ref))
/* pfree(output_proj4); */
pj_free(input_pj);
pfree(geom);
- elog(ERROR, "transform: couldn't parse proj4 output string: '%s':
%s", output_proj4, pj_strerrno(pj_errno));
+ elog(ERROR, "transform: couldn't parse proj4 output string: '%s':
%s", output_proj4, pj_strerrno(*pj_errno_ref));
PG_RETURN_NULL();
@@ -999,7 +1010,7 @@
PG_FUNCTION_INFO_V1(postgis_proj_version);
Datum postgis_proj_version(PG_FUNCTION_ARGS)
- const char *ver = pj_release;
+ const char *ver = pj_get_release();
text *result;
result = (text *) palloc(VARHDRSZ + strlen(ver));
SET_VARSIZE(result, VARHDRSZ + strlen(ver));
@@ -1011,23 +1022,28 @@
int
transform_point(POINT4D *pt, PJ *srcpj, PJ *dstpj)
if (srcpj->is_latlong) to_rad(pt);
pj_transform(srcpj, dstpj, 1, 2, &(pt->x), &(pt->y), &(pt->z));
- if (pj_errno)
+ if (*pj_errno_ref)
- if (pj_errno == -38) /*2nd chance */
+ if ((*pj_errno_ref) == -38) /*2nd chance */
elog(WARNING, "transform: %i (%s)",
- pj_errno, pj_strerrno(pj_errno));
+ *pj_errno_ref, pj_strerrno(*pj_errno_ref));
/*couldnt do nadshift - do it without the datum */
pj_transform_nodatum(srcpj, dstpj, 1, 2,
&(pt->x), &(pt->y), NULL);
- if (pj_errno)
+ if ((*pj_errno_ref))
elog(ERROR,"transform: couldn't project point: %i (%s)",
return 0;
Only in .: lwpostgis.sql
Only in .: msvc.patch
Only in .: msvc_new.patch
Only in ./regress: lwpostgis.sql
--- /c/temp/postgis-1.3.1/config.h.vc 1969-12-31 17:00:00 -0700
+++ ./config.h.vc 2007-08-28 16:27:19 -0600
@@ -0,0 +1,9 @@
+#define POSTGIS_VERSION "1.3.1"
+#define REL_MAJOR_VERSION "1"
+#define REL_MINOR_VERSION "3"
+#define REL_MICRO_VERSION "1"
+#define POSTGIS_LIB_VERSION POSTGIS_VERSION
+#define POSTGIS_BUILD_DATE "2007-08-23"
+#define POSTGIS_SCRIPTS_VERSION POSTGIS_LIB_VERSION
+#define USE_GEOS 1
\ No newline at end of file
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070828/2b21b053/attachment.bin>
