SPAM: [postgis-users] need restore assistance
Josh Livni
josh at umbrellaconsulting.com
Mon Dec 10 13:27:07 PST 2007
Kirk,
Of course I'm not sure how your database was backed up, but chances are
you can get your data back somehow.
I would first try a few things - if one in particular fails, it may help
others isolate the trouble if you can give specific errors it failed
with. The command examples in parenthesis are from command line:
- create brand new new database for the restore
- ensure the database has plpgsql -- (createlang plpgsql <database>)
- ensure spatial_ref_sys and geometry_columns tables do _not_ exist in
the new database (in case they were in your template; drop them if
necessary)
- run lwpostgis.sql -- (psql -f /usr/share/lwpostgis.sql -d <database>)
and make sure it runs fine
- add spatial ref columns -- (psql -f /usr/share/lwpostgis_upgrade.sql
-d <database>)
- try restore -- (pg_restore -C -d <database> )
-Josh
Kirk Wythers wrote:
> I set up a new machine and am trying to do a restore from a
> pg_dumpall. First question, is this possible. I noticed after running
> the command:
> psql 'file_to_restore' postgres
> that for the most part, all of the databases get restored, however, tables
> that contain spatial info (such as the_geom) are missing from their
> respective databases.
> I was reading the documentation and see a reference to a "Hard
> Restore" using
> sh utils/postgis_restore.pl lwpostgis.sql newdb olddb.dump -E=UNICODE
> > restore.log
> But I can't find postgis_restore.pl on my system.
> Additionally, I am concerned
> that the pg_dumpall may not have bee done with -Fc. Can a pg_dumpall
> be restored if it contains spatial info from postgis?
> It looks like I am about to learn the hard way how to do a proper
> postgis backup, and that the postgresql procedures I am used to, may
> not be sufficient.
> Thanks for any advice that might help me get this db back up
> Kirk
> postgis-users mailing list
