[postgis-users] shp2pgsql problem
Willy-Bas Loos
willybas at gmail.com
Thu Dec 13 04:15:55 PST 2007
here's the rest of the shapefile (still one record, attached).
On Dec 13, 2007 11:04 AM, Willy-Bas Loos <willybas at gmail.com> wrote:
> Hi,
> I have a small problem wit shp2pgsql, it doesn't convert my colleague's
> shapefile correctly.
> I've attached the 1rec shapefile and the shp2pgsql result in this mail,
> hope that works.
> I'm using this version: RCSID: $Id: shp2pgsql.c,v 1.88.2.7 2005/08/29
> 22:36:14 strk Exp $
> on windows XP.
> The problem is in two of the boolean fields: "microrelie" boolean and
> "macrorelie" boolean.
> They are both created, but their values don't make it into the INSERT
> statement. They turn up as empty strings, which is illegal SQL.
> There are lots (37) of fields in the shapefile.
> 12 other boolean fields are handled correctly.
> The "bad" fields are the 24th and the 25th field.
> is this some bug?
> WBL
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071213/0775e7b9/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071213/0775e7b9/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071213/0775e7b9/attachment-0001.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071213/0775e7b9/attachment-0002.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071213/0775e7b9/attachment-0003.obj>
