[postgis-users] shp2pgsql problem
Willy-Bas Loos
willybas at gmail.com
Thu Dec 13 02:04:58 PST 2007
I have a small problem wit shp2pgsql, it doesn't convert my colleague's
shapefile correctly.
I've attached the 1rec shapefile and the shp2pgsql result in this mail, hope
that works.
I'm using this version: RCSID: $Id: shp2pgsql.c,v 1.88.2.7 2005/08/29
22:36:14 strk Exp $
on windows XP.
The problem is in two of the boolean fields: "microrelie" boolean and
"macrorelie" boolean.
They are both created, but their values don't make it into the INSERT
statement. They turn up as empty strings, which is illegal SQL.
There are lots (37) of fields in the shapefile.
12 other boolean fields are handled correctly.
The "bad" fields are the 24th and the 25th field.
is this some bug?
WBL
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071213/505c5cad/attachment.html>
Type: application/x-dbase
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071213/505c5cad/attachment.bin>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071213/505c5cad/attachment.obj>
