[postgis-users] Loading data with ogr2ogr
Obe, Regina
robe.dnd at cityofboston.gov
Thu Dec 13 04:17:59 PST 2007
Not sure if it makes a difference, but I usually quote the "EPSG:32633", but I've never imported from SDE so could be a totally different issue.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Pål Kristensen
Sent: Thursday, December 13, 2007 6:17 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Loading data with ogr2ogr
Hi!
I have loaded some data from ArcSDE 9.1 to PostGIS using the ogr2ogr
utility. The load statements typically looks like this:
ogr2ogr -nlt LINESTRING -nln n50_begrensningskurve -lco
GEOMETRY_NAME=the_geom -a_srs EPSG:32633 -f PostgreSQL PG:"dbname=kartdata
user=**** host=***.***.***.***"
SDE:***.***.***.***,5157,,sde_user,sde_password,n50.begrensningskurve
The problem is that the resulting table in PostGIS has a SRID value of 1,
but it should be 32633. I have tried to include the s_srs option to override
the source projection, which by the way is 32633, but that did not do any
difference.
I have used the UpdateGeometrySRID function to change the SRID after
loading, but that seems like a workaround that really not should be
necessary.
Is there something I've missed that causes this behavior? Any ideas?
Regards,
Pål Kristensen
View this message in context: http://www.nabble.com/Loading-data-with-ogr2ogr-tp14313629p14313629.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
