[postgis-users] Creating a template for postgis-enabled databases?
Sebastien ARBOGAST
sebastien.arbogast at gmail.com
Sun Dec 16 06:41:09 PST 2007
Yes! That worked great. Thanks to both of you.
2007/12/16, LuVar <varga.lubomir at orangemail.sk>:
> Jop. I get also the same. Just try to disconnect in pgAdmin and
> reconnect. Than click ONLY on that database, in which you want to do
> somethink. Dont open "template_postgis" table. You must have an red
> cross iccon on "template_postgis" database.
> Try, and good luck.
> Sunday, December 16, 2007, 3:25:11 PM, you wrote:
> > I just did that and I can't create a database based on template_postgis.
> > When I try to do it via pgAdmin, I get a message saying that "Source
> > database "template_postgis" is being accessed by other users
> > When I try to run the command in terminal, I get the following message:
> > createdb: could not connect to database template1: could not translate
> > host name "tagspot_local" to address: nodename nor servname provided,
> > or not known
> > 2007/12/16, Shoaib Burq <shoaib at nomad-labs.com>:
> >> Sebastian, please see:
> >> http://geospatial.nomad-labs.com/2007/12/16/template-postgis-database/
> >> shoaib
> >> On Dec 16, 2007 10:15 AM, Sebastien ARBOGAST <sebastien.arbogast at gmail.com>
> >> wrote:
> >> > Hi,
> >> > I've just installed postgresql 8.2.5 and postgis 1.3.2 on my mac and
> >> > everything works great so far. Now I'm just looking for a way to
> >> > simplify the creation of postgis-enabled databases in pgAdmin.
> >> > I saw that in the Windows distribution, there is a template to do so,
> >> > but there is no such template in my installation. Knowing that it's
> >> > the first time that I use postgresql and postgis, is there a way to
> >> > create such a template?
> >> > Sébastien Arbogast
> >> > http://www.sebastien-arbogast.com
> >> > _______________________________________________
> >> > postgis-users mailing list
> >> > postgis-users at postgis.refractions.net
> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Best regards,
> LuVar mailto:varga.lubomir at orangemail.sk
Sébastien Arbogast
