[postgis-users] Creating a template for postgis-enabled databases?
LuVar
varga.lubomir at orangemail.sk
Sun Dec 16 06:29:58 PST 2007
Jop. I get also the same. Just try to disconnect in pgAdmin and
reconnect. Than click ONLY on that database, in which you want to do
somethink. Dont open "template_postgis" table. You must have an red
cross iccon on "template_postgis" database.
Try, and good luck.
Sunday, December 16, 2007, 3:25:11 PM, you wrote:
> I just did that and I can't create a database based on template_postgis.
> When I try to do it via pgAdmin, I get a message saying that "Source
> database "template_postgis" is being accessed by other users
> When I try to run the command in terminal, I get the following message:
> createdb: could not connect to database template1: could not translate
> host name "tagspot_local" to address: nodename nor servname provided,
> or not known
> 2007/12/16, Shoaib Burq <shoaib at nomad-labs.com>:
>> Sebastian, please see:
>> http://geospatial.nomad-labs.com/2007/12/16/template-postgis-database/
>> shoaib
>> On Dec 16, 2007 10:15 AM, Sebastien ARBOGAST <sebastien.arbogast at gmail.com>
>> wrote:
>> > Hi,
>> > I've just installed postgresql 8.2.5 and postgis 1.3.2 on my mac and
>> > everything works great so far. Now I'm just looking for a way to
>> > simplify the creation of postgis-enabled databases in pgAdmin.
>> > I saw that in the Windows distribution, there is a template to do so,
>> > but there is no such template in my installation. Knowing that it's
>> > the first time that I use postgresql and postgis, is there a way to
>> > create such a template?
>> > Sébastien Arbogast
>> > http://www.sebastien-arbogast.com
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Best regards,
LuVar mailto:varga.lubomir at orangemail.sk
