[postgis-users] geomunion revisited....
Craig de Stigter craig.destigter at onetrackmind.co.nz
Mon Dec 17 13:45:56 PST 2007
I had to Union geometries with a high degree of overlap, and the ST_Union
function was far too slow (union on 18,000 polygons took over two hours.)
So I wrote a pl/pgsql implementation of CascadedUnion, which will tide me
over till PostGIS gets its own CascadedUnion.
The first function is a convenience function that just discovers the initial
extent of the table and calls the second function.
The second function is recursive and splits the extent until there are fewer
than a certain number of points, calling ST_Union on such subsets.
So for example:
> SELECT CascadedUnion('public', 'mytable', 'the_geom', 1000);
will split the bounding box recursively until there are fewer than 1000
geometries in each box, and call ST_Union on each of these subsets.
For my (highly overlapping) data set, this does in 18 seconds what a plain
ST_Union took more than two hours to do. For non-overlapping datasets it
will work out slower.
Heres the code:
> CREATE OR REPLACE FUNCTION CascadedUnion(character varying, character
> varying, character varying, integer)
RETURNS geometry AS
> $BODY$
> DECLARE
>     curs1 refcursor;
>     bounds BOX2D;
> BEGIN
>     OPEN curs1 FOR EXECUTE 'SELECT extent(' || $3 || ') FROM ' || $1 ||
> '.' || $2;
>     FETCH curs1 INTO bounds;
>     RETURN CascadedUnion($1, $2, $3, $4, bounds);
> END;
> $BODY$
> LANGUAGE 'plpgsql' VOLATILE;
> varying, character varying, integer, box3d)
> RETURNS geometry AS
> $BODY$
> DECLARE
>     end_geom GEOMETRY;
>     bounds BOX3D;
>     bounds1 BOX3D;
>     bounds2 BOX3D;
>     numfeatures integer;
>     curs1 refcursor;
>     curs2 refcursor;
>     max_x real;
>     max_y real;
>     min_x real;
>     min_y real;
>     result1 geometry;
>     result2 geometry;
>     emptygeom geometry;
> BEGIN
>     max_x := xmax($5);
>     min_x := xmin($5);
>     max_y := ymax($5);
>     min_y := ymin($5);
>     select into bounds $5;
>     OPEN curs1 FOR EXECUTE 'SELECT count(*) FROM ' || $1 || '.' || $2 || '
> WHERE ' || $3 || ' && setsrid(box2d(''BOX(' || min_x || ' ' || min_y || ','
> || max_x || ' ' || max_y || ')''), srid(' || $3 || ')) AND
> intersects(centroid(' || $3 || '), setsrid(box2d(''BOX(' || min_x || ' ' ||
> min_y || ',' || max_x || ' ' || max_y || ')''), srid(' || $3 || ')))';
>     FETCH curs1 INTO numfeatures;
>     IF numfeatures < $4 THEN
>         OPEN curs2 FOR EXECUTE 'select st_union(' || $3 || ') from ' || $1
> || '.' || $2 || ' where ' || $3 || ' && setsrid(box2d(''BOX(' || min_x || '
> ' || min_y || ',' || max_x || ' ' || max_y || ')''), srid(' || $3 || ')) AND
>         FETCH curs2 INTO end_geom;
>     ELSE
>         --split in longest dimension
>         IF max_x - min_x > max_y - min_y THEN
>             bounds1 := makebox3d(makepoint(min_x, min_y),
> makepoint((max_x+min_x)/2, max_y));
>             bounds2 := makebox3d(makepoint((max_x + min_x)/2, min_y),
> makepoint(max_x, max_y));
>         ELSE
>             bounds1 := makebox3d(makepoint(min_x, min_y), makepoint(max_x,
> (max_y+min_y)/2));
>             bounds2 := makebox3d(makepoint(min_x, (max_y+min_y)/2),
>         END IF;
>         --recurse
>         SELECT INTO result1 CascadedUnion($1, $2, $3, $4, bounds1);
>         SELECT INTO result2 CascadedUnion($1, $2, $3, $4, bounds2);
>         SELECT INTO emptygeom geomfromtext('GEOMETRYCOLLECTION(EMPTY)',
> find_srid($1, $2, $3));
>         SELECT INTO end_geom st_union(coalesce(result1, emptygeom),
> coalesce(result2, emptygeom));
>     END IF;
>     RETURN end_geom;
> END;
> $BODY$
Regards
Craig
One Track Mind Ltd.
PO Box 1604, Shortland St, Auckland, New Zealand
Phone +64-9-966 0433 Fax +64-9-969 0045
Web http://www.onetrackmind.co.nz
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071218/b317bf3b/attachment.html>
