[postgis-users] geomunion revisited....
Kevin Neufeld
kneufeld at refractions.net
Mon Dec 17 13:58:43 PST 2007
Very nice, Craig. This is definitely the better approach when
attempting to union a large set of geometries instead of the naive
aggregate approach st_union currently employs. Hopefully we can add
something similar in PostGIS soon.
Cheers,
-- Kevin
Kevin Neufeld
Software Developer
Refractions Research Inc.
300-1207 Douglas St.
Victoria, B.C., V8W 2E7
Phone: (250) 383-3022
Email: kneufeld at refractions.net
Craig de Stigter wrote:
> I had to Union geometries with a high degree of overlap, and the
> ST_Union function was far too slow (union on 18,000 polygons took over
> two hours.)
> So I wrote a pl/pgsql implementation of CascadedUnion, which will tide
> me over till PostGIS gets its own CascadedUnion.
> The first function is a convenience function that just discovers the
> initial extent of the table and calls the second function.
> The second function is recursive and splits the extent until there are
> fewer than a certain number of points, calling ST_Union on such subsets.
> So for example:
> SELECT CascadedUnion('public', 'mytable', 'the_geom', 1000);
> will split the bounding box recursively until there are fewer than
> 1000 geometries in each box, and call ST_Union on each of these subsets.
> For my (highly overlapping) data set, this does in 18 seconds what a
> plain ST_Union took more than two hours to do. For non-overlapping
> datasets it will work out slower.
> Heres the code:
> CREATE OR REPLACE FUNCTION CascadedUnion(character varying,
> character varying, character varying, integer)
> RETURNS geometry AS
> $BODY$
> DECLARE
> curs1 refcursor;
> bounds BOX2D;
> BEGIN
> OPEN curs1 FOR EXECUTE 'SELECT extent(' || $3 || ') FROM ' ||
> $1 || '.' || $2;
> FETCH curs1 INTO bounds;
> RETURN CascadedUnion($1, $2, $3, $4, bounds);
> END;
> $BODY$
> LANGUAGE 'plpgsql' VOLATILE;
> character varying, character varying, integer, box3d)
> RETURNS geometry AS
> $BODY$
> DECLARE
> end_geom GEOMETRY;
> bounds BOX3D;
> bounds1 BOX3D;
> bounds2 BOX3D;
> numfeatures integer;
> curs1 refcursor;
> curs2 refcursor;
> max_x real;
> max_y real;
> min_x real;
> min_y real;
> result1 geometry;
> result2 geometry;
> emptygeom geometry;
> BEGIN
> max_x := xmax($5);
> min_x := xmin($5);
> max_y := ymax($5);
> min_y := ymin($5);
> select into bounds $5;
> OPEN curs1 FOR EXECUTE 'SELECT count(*) FROM ' || $1 || '.' ||
> $2 || ' WHERE ' || $3 || ' && setsrid(box2d(''BOX(' || min_x || '
> ' || min_y || ',' || max_x || ' ' || max_y || ')''), srid(' || $3
> || ')) AND intersects(centroid(' || $3 || '),
> setsrid(box2d(''BOX(' || min_x || ' ' || min_y || ',' || max_x ||
> ' ' || max_y || ')''), srid(' || $3 || ')))';
> FETCH curs1 INTO numfeatures;
> IF numfeatures < $4 THEN
> OPEN curs2 FOR EXECUTE 'select st_union(' || $3 || ') from
> ' || $1 || '.' || $2 || ' where ' || $3 || ' &&
> ' ' || max_y || ')''), srid(' || $3 || ')) AND
> intersects(centroid(' || $3 || '), setsrid(box2d(''BOX(' || min_x
> || ' ' || min_y || ',' || max_x || ' ' || max_y || ')''), srid('
> || $3 || ')))';
> FETCH curs2 INTO end_geom;
> ELSE
> --split in longest dimension
> IF max_x - min_x > max_y - min_y THEN
> bounds1 := makebox3d(makepoint(min_x, min_y),
> makepoint((max_x+min_x)/2, max_y));
> bounds2 := makebox3d(makepoint((max_x + min_x)/2,
> min_y), makepoint(max_x, max_y));
> ELSE
> makepoint(max_x, (max_y+min_y)/2));
> bounds2 := makebox3d(makepoint(min_x,
> (max_y+min_y)/2), makepoint(max_x, max_y));
> END IF;
> --recurse
> SELECT INTO result1 CascadedUnion($1, $2, $3, $4, bounds1);
> SELECT INTO result2 CascadedUnion($1, $2, $3, $4, bounds2);
> SELECT INTO emptygeom
> geomfromtext('GEOMETRYCOLLECTION(EMPTY)', find_srid($1, $2, $3));
> SELECT INTO end_geom st_union(coalesce(result1,
> emptygeom), coalesce(result2, emptygeom));
> END IF;
> RETURN end_geom;
> END;
> $BODY$
> Regards
> Craig
> One Track Mind Ltd.
> PO Box 1604, Shortland St, Auckland, New Zealand
> Phone +64-9-966 0433 Fax +64-9-969 0045
> Web http://www.onetrackmind.co.nz
> postgis-users mailing list
