[postgis-users] Spatial index in stored function
Santosh Gaikwad Santosh.Gaikwad at saama.com
Tue Dec 18 02:04:54 PST 2007
I have created the spatial index on geometry column in my table. I also
made a stored function which uses the following query inside it.
-- Function: applyradioustraffic(clongitude double precision, clatitude
double precision, radiusinmeters double precision)
-- DROP FUNCTION applyradioustraffic(clongitude double precision,
clatitude double precision, radiusinmeters double precision);
CREATE OR REPLACE FUNCTION applyradioustraffic(clongitude double
precision, clatitude double precision, radiusinmeters double precision)
  RETURNS SETOF t_traffic AS
$BODY$
   DECLARE rec t_traffic%ROWTYPE;
   begin
       FOR rec IN
            SELECT avg(traffic_vol)from psl_traffic
where
     st_dwithin(
      transform(the_geom,2163),
      transform(GeomFromText('POINT(' || clongitude || ' ' || clatitude
||')',4326),2163),
      radiusInMeters) and (cnt_type like 'ADT%')
LOOP
           -- additional processing if any goes here --
                        return next rec;
            END LOOP;
       return;
   end;
$BODY$
  LANGUAGE 'plpgsql' VOLATILE;
ALTER FUNCTION applyradioustraffic(clongitude double precision,
clatitude double precision, radiusinmeters double precision) OWNER TO
postgres;
When I run the query, it gives me faster result and shows it is using
spatial index after doing explain analyze. When I do explain analyze for
the stored function it doesn't not it is using spatial index. I would
like to know whether spatial indexes are getting used in stored function
or not. My stored function is result is bit slower.
Thanks & Regards,
Santosh Gaikwad
Senior Software Developer
Saama Technologies (India) Pvt. Ltd.,
Unit No.101-102, First floor,
Weikfield IT CITI INFO PARK,
Weikfield estates,
Pune Nagar Road,
Pune - 411 014. India
Phone : +91 20 66071397
Mobile: +91-9422005927
E-mail :Santosh.Gaikwad at saama.com
http://www.saama.com <http://www.saama.com>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071218/ebed796d/attachment.html>
Name: Santosh Gaikwad.vcf
Type: text/x-vcard
Desc: Santosh Gaikwad.vcf
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071218/ebed796d/attachment.vcf>
