[postgis-users] ST_contains() throws an error
James DeMichele
James.DeMichele at redfin.com
Fri Dec 28 11:24:48 PST 2007
I have a table with 27000 records and each record has 2 geometry
columns. The first column has an original MULTIPOLYGON (named
original_poly), and the second column has some tweaks (buffer and
simplification) applied to the original data, and is also stored as a
MULTIPOLYGON (named new_poly).
I want to get the list of these rows where the new_poly does NOT contain
the original_poly. The first time I ran it, I got this: "ERROR: GEOS
contains() threw an error!"
So, then I thought that maybe some of the polygons were not valid. There
were 6 invalid polygons, so then I tried running this query:
select count(*)
from temp_places_buffer
where(st_isvalid(new_poly) = true and st_isvalid(redfin_poly) = true)
and not st_contains(t1.new_poly, t1.redfin_poly);
Unfortunately, I still get this error:
ERROR: GEOS contains() threw an error!
What are possible reasons that this would still be throwing an error,
other than invalid polygons, since the query should now only be
calculating st_contains on valid polygons?
I am running this version:
postgis_version
1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
Thanks.
-James
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071228/7e43ede8/attachment.html>
