[postgis-users] ST_contains() throws an error
Obe, Regina robe.dnd at cityofboston.gov
Mon Dec 31 03:45:35 PST 2007
Not quite enough information there to guess.
select  postgis_full_version();
instead of postgis_version()
That will give the exact Geos version you are running.
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
James DeMichele
Sent: Friday, December 28, 2007 2:25 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] ST_contains() throws an error
I have a table with 27000 records and each record has 2 geometry
columns. The first column has an original MULTIPOLYGON (named
original_poly), and the second column has some tweaks (buffer and
simplification) applied to the original data, and is also stored as a
MULTIPOLYGON (named new_poly).
I want to get the list of these rows where the new_poly does NOT contain
the original_poly. The first time I ran it, I got this: "ERROR:  GEOS
contains() threw an error!"
So, then I thought that maybe some of the polygons were not valid. There
were 6 invalid polygons, so then I tried running this query:
select count(*)
from temp_places_buffer
where(st_isvalid(new_poly) = true and st_isvalid(redfin_poly) = true)
and not st_contains(t1.new_poly, t1.redfin_poly);
Unfortunately, I still get this error:
ERROR:  GEOS contains() threw an error!
What are possible reasons that this would still be throwing an error,
other than invalid polygons, since the query should now only be
calculating st_contains on valid polygons?
I am running this version:
            postgis_version
 1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
Thanks.
-James
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071231/02c3b0b1/attachment.html>
