[postgis-users] shp2pgsql problem with Leopard
    david.techer at davidgis.fr
    Sun Dec 30 09:08:08 PST 2007
Hi David,
Did U try to specify a table name
shp2pgsql <your/options> <path/to/shapefile> <table> |psql ...
Quoting David Garbin <dgarbin at verizon.net>:
> I am using PostgreSQL/Postgis with Leopard using the latest Kyng Chaos
> binaries.  Everything appears to be working well except shp2pgsql.
> When I try to load a shapefile, it just gives me the help screen (see
> below):
> [Big-Mac:~] dgarbin% /usr/local/pgsql/bin/shp2pgsql -D -s 4269 -i -I
> /Users/dgarbin/grass/Shapefiles/dtl_cnty.shp dgarbin.dtl_cnty |
> /usr/local/pgsql/bin/psql -d networx
> RCSID: $Id: shp2pgsql.c 2717 2007-11-23 10:42:09Z mcayland $ RELEASE: 1.3.2
> USAGE: /usr/local/pgsql/bin/shp2pgsql [<options>] <shapefile>
> [<schema>.]<table>
> OPTIONS:
>   -s <srid>  Set the SRID field. If not specified it defaults to -1.
>   (-d|a|c|p) These are mutually exclusive options:
>       -d  Drops the table, then recreates it and populates
>           it with current shape file data.
>       -a  Appends shape file into current table, must be
>           exactly the same table schema.
>       -c  Creates a new table and populates it, this is the
>           default if you do not specify any options.
>       -p  Prepare mode, only creates the table.
>   -g <geometry_column> Specify the name of the geometry column
>      (mostly useful in append mode).
>   -D  Use postgresql dump format (defaults to sql insert statments.
>   -k  Keep postgresql identifiers case.
>   -i  Use int4 type for all integer dbf fields.
>   -I  Create a GiST index on the geometry column.
>   -S  Generate simple geometries instead of MULTI geometries.
>   -w  Use wkt format (for postgis-0.x support - drops M - drifts
> coordinates).
>   -W <encoding> Specify the character encoding of Shape's
>      attribute column. (default : "ASCII")
>   -N <policy> Specify NULL geometries handling policy (insert,skip,abort)
>   -? Display this help screen
> There seems to be a problem reading parameters.  If I just specify the
> -? option, it says "No match".
> postgis-users mailing list
