[postgis-users] shp2pgsql problem with Leopard
David Garbin
dgarbin at verizon.net
Sun Dec 30 10:58:53 PST 2007
Thanks for all the quick replies. About the table name issue, I
believe the argument "dgarbin.dtl_cnty" is the table name (schema
qualified). If my syntax is wrong, let me know.
On Dec 30, 2007, at 12:08 PM, david.techer at davidgis.fr wrote:
> Hi David,
> Did U try to specify a table name
> shp2pgsql <your/options> <path/to/shapefile> <table> |psql ...
> Quoting David Garbin <dgarbin at verizon.net>:
>> I am using PostgreSQL/Postgis with Leopard using the latest Kyng
>> Chaos
>> binaries. Everything appears to be working well except shp2pgsql.
>> When I try to load a shapefile, it just gives me the help screen (see
>> below):
>> [Big-Mac:~] dgarbin% /usr/local/pgsql/bin/shp2pgsql -D -s 4269 -i -I
>> /Users/dgarbin/grass/Shapefiles/dtl_cnty.shp dgarbin.dtl_cnty |
>> /usr/local/pgsql/bin/psql -d networx
>> RCSID: $Id: shp2pgsql.c 2717 2007-11-23 10:42:09Z mcayland $
>> RELEASE: 1.3.2
>> USAGE: /usr/local/pgsql/bin/shp2pgsql [<options>] <shapefile>
>> [<schema>.]<table>
>> OPTIONS:
>> -s <srid> Set the SRID field. If not specified it defaults to -1.
>> (-d|a|c|p) These are mutually exclusive options:
>> -d Drops the table, then recreates it and populates
>> it with current shape file data.
>> -a Appends shape file into current table, must be
>> exactly the same table schema.
>> -c Creates a new table and populates it, this is the
>> default if you do not specify any options.
>> -p Prepare mode, only creates the table.
>> -g <geometry_column> Specify the name of the geometry column
>> (mostly useful in append mode).
>> -D Use postgresql dump format (defaults to sql insert statments.
>> -k Keep postgresql identifiers case.
>> -i Use int4 type for all integer dbf fields.
>> -I Create a GiST index on the geometry column.
>> -S Generate simple geometries instead of MULTI geometries.
>> -w Use wkt format (for postgis-0.x support - drops M - drifts
>> coordinates).
>> -W <encoding> Specify the character encoding of Shape's
>> attribute column. (default : "ASCII")
>> -N <policy> Specify NULL geometries handling policy
>> (insert,skip,abort)
>> -? Display this help screen
>> There seems to be a problem reading parameters. If I just specify
>> the
>> -? option, it says "No match".
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
