[postgis-users] How best to do this?
Stephen Woodbridge woodbri at swoodbridge.com
Thu Feb 1 19:34:38 PST 2007
Hi all,
Sorry the subject line is not more useful, but let me explain.
1) I have a set of polgons A and another set of polygon B
2) I need to a new set of polygons C that are the union of
    A intersect B and A difference B
So basically B partially covers A and I want to split polygons in a into
the covered piece(s) and that that is not covered.
On the surface this is very straight forward, but it isn't ...
insert into newtable (....)
    select ..., intersection(A.the_geom, B.the_geom) as the_geom
      from A, B
      where A.the_geom && B.the_geom and
        intersects(A.the_geom, B.the_geom);
This works, but I get a bunch of GEOMETRYCOLLECTION objects in the
results and out of 1022 collection I have 2780 additional POLYGONs.
So I could do something like:
     select * from
       (select ..., (dump(the_geom)).geom as the_geom from newtable
          where geometrytype(the_geom)='GEOMETRYCOLLECTION' ) as foo
     where geometrytype(the_geom)='POLYGON';
delete from newtable where geometrytype(the_geom)='GEOMETRYCOLLECTION';
So now comes the tricky part how do you do the difference? I was
thinking I could take A difference newtable but because I have multiple
little pieces instead of a single piece, I think I am getting:
   (A - Part1), (A - Part2), (A - Part3) instead of
   (A - Part1 - Part2 - Part3)
So I think I need to union the polygon pieces from each row that is
dumped above. Is that as simple as tossing part of the dump into a
geomunion()? How would that look?
-Steve W
