[postgis-users] pg_restore problem - linked to different versions?
Stefan Schwarzer stefan.schwarzer at grid.unep.ch
Fri Feb 2 06:27:33 PST 2007
>> I dumped my locally newly created database and wanted to restore on
>> the server. But I got this message.
>> pg_restore: [archiver] unsupported version (1.10) in file header
>> pg_restore call failed
>> I guess the problem comes from the fact that:
>>    the server runs with     PostGres 8.1.0 and PostGIS 1.1.2
>>    my local machine with PostGres 8.1.2 and PostGIS 1.1.1
>> Could that be? And what can I do to solve the problem? In the moment
>> we won't touch our server, as it runs smoothly. And on my local
>> machine, a Mac, the different packages have been installed via the
>> prebuild packages from KyngChaos. I am no compiler.... So, not too
>> keen to re-compile Postgres and Postgis.... But I guess it's what I
>> have to do, right?
>> Thanks for any hints...
> Hi Stefan,
> Could it be that you have multiple versions of pg_restore on your
> server? Looking at the PostgreSQL source code, version 1.10 headers
> were
> introduced with the advent of tablespaces (PostgreSQL 8.0) and so you
> are attempting to restore your pg_dump with a pg_restore for
> PostgreSQL
> < 8.0.
> So you need to check your paths and make sure you are using the
> pg_restore from your PostgreSQL 8.1 installation. Perhaps if you
> installed PostgreSQL 8.1 yourself, you need to be using the version
> in /usr/local/bin rather than the version in /usr/bin which originally
> came with your distro?
Great Mark,
you were absolutely right! There were two or three references to
pg_restore; only one of them version 8, and not the default one.
Thanks a lot!!!
