[postgis-users] Geocoding
Rob Tester robtester at gmail.com
Fri Feb 2 12:29:48 PST 2007
I think that the task of geocoding is fairly easy and I have written a
geocode function that uses PostGIS. However, the problem is where to get the
data. In the U.S. you can use Tiger line data from the census, but it is
horrible inaccurate.  If you have resources you can purchase more accurate
data from other companies like Navteq, or manually correct the census data.
Rob.
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stone,
Matthew (DHS-HISP)
Sent: Friday, February 02, 2007 1:15 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Geocoding
Does/Will PostGis have a Geocoding routine built in such as ArcSDE has
locators and geocoding processing?  I am curious, as geocoding is the
building block of any GIS work I do and I have need of decent open-source
solutions that can process millions of records in a batch mode, or can be
implemented on the WEB as a "geocoding service" either again in batch mode,
or real time via other web-based applications.  I understand the limitations
of this functionality in an open-source environment, namely the ability of
getting decent reference data, but am curious all the same.
Maybe a module could be built that accesses the geocoding services provided
by Google or Yahoo, of MS Virtual Earth??????
Just thought I would throw this out there.
Matthew
Matthew Stone, MPH
UCSF/CA Dept. of Health Services
Health Information & Strategic Planning (HISP)
Office of County Health Services (OCHS)
1501 Capitol Ave MS 5204
Mailing Address:
PO BOX 997413, MS 5204
Sacramento CA 95899-7413
Physical Address:
1501 Capitol Avenue, Suite 71.5195, MS 5204
Sacramento, CA 95814
_____________________________
PH: 916-552-9918
FAX: 916-552-8260
mstone at dhs.ca.gov
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070202/5dad45ee/attachment.html>
