[postgis-users] Geocoding
Brad Ediger brad at bradediger.com
Fri Feb 2 12:39:10 PST 2007
Yes, the TIGER/Line data can be horribly inaccurate, and the Navteq/
Tele Atlas data is horribly expensive.
Google Maps provides a geocoder web service (http://www.google.com/
apis/maps/documentation/#Geocoding_Examples) via HTTP but it is rate-
limited to 50,000 requests per day. They have some commercial-use
restrictions, IIRC, and you can't use any of the GMaps services for
real-time tracking. But it might fit the bill.
Their commercial-use service is pretty darn expensive, too. Starts at
$10,000 per year and goes up from there.
hth,
Brad
On Feb 2, 2007, at 2:29 PM, Rob Tester wrote:
> I think that the task of geocoding is fairly easy and I have
> written a geocode function that uses PostGIS. However, the problem
> is where to get the data. In the U.S. you can use Tiger line data
> from the census, but it is horrible inaccurate.  If you have
> resources you can purchase more accurate data from other companies
> like Navteq, or manually correct the census data.
> Rob.
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-
> users-bounces at postgis.refractions.net] On Behalf Of Stone, Matthew
> (DHS-HISP)
> Sent: Friday, February 02, 2007 1:15 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Geocoding
> Does/Will PostGis have a Geocoding routine built in such as ArcSDE
> has locators and geocoding processing?  I am curious, as geocoding
> is the building block of any GIS work I do and I have need of
> decent open-source solutions that can process millions of records
> in a batch mode, or can be implemented on the WEB as a “geocoding
> service” either again in batch mode, or real time via other web-
> based applications.  I understand the limitations of this
> functionality in an open-source environment, namely the ability of
> getting decent reference data, but am curious all the same.
> Maybe a module could be built that accesses the geocoding services
> provided by Google or Yahoo, of MS Virtual Earth??????
> Just thought I would throw this out there.
> Matthew
> Matthew Stone, MPH
> UCSF/CA Dept. of Health Services
> Health Information & Strategic Planning (HISP)
> Office of County Health Services (OCHS)
> 1501 Capitol Ave MS 5204
> Mailing Address:
> PO BOX 997413, MS 5204
> Sacramento CA 95899-7413
> Physical Address:
> 1501 Capitol Avenue, Suite 71.5195, MS 5204
> Sacramento, CA 95814
> _____________________________
> PH: 916-552-9918
> FAX: 916-552-8260
> mstone at dhs.ca.gov
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070202/025cf519/attachment.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070202/025cf519/attachment.bin>
