[postgis-users] Need an answer for somebody new to GIS and PostGIS
Brian Harbick brhar at mac.com
Sat Feb 3 11:26:16 PST 2007
I have a data set of 1 million rows of addresses that have lat/long.
I do not know the source of the geocoding.
I need to be able to query the database for addresses within 10 miles
of a point.
I have compared my attempts with results with results from Google API.
On one address, google said it was 8 miles away. PostGIS results said
4 miles. Since, I live in the area that I tested 8 miles is most
likely the correct answer.
I have tried using SRID -1 and 4326 and both do not match with google.
I admit I have been hacking at this for two weeks and read hundreds
of posts in the forum, but have not found an answers that I can rely on.
I think that PostGIS is meant for point in polygon type queries,
which I will need next. but, right now I am just trying to make sure
I understand how to setup the geometry correctly to test for miles.
Please help point in the right direction with as much detail as
possible.
Thank You.
